LibreELEC & OpenELEC for Tronsmart Vega S95
Hi again.
I have some subtitle issues with the current Kodi 17 version in te LibreElec installation. I cannot move the subtitles on the screen up or down.
How can I replace the Kodi version in the LibreElec version? Or can you provide an update?
I tried a development build from the Kodi website on my Android in Tronsmart Vega S95 and with that Kodi I can move the subtitles again.
The version I tried was kodi-20170119-53a5c83-Krypton-armeabi-v7a
Originally posted by balbes150 View Post
It is desirable to provide a link to the file and the steps You did. I think it will helpful for other users.
I think you misunderstood my question.
I did not replace the Kodi version with the version I mentioned above.
I want to know how to do this or if you can provide an updated image.
Henk
Hi
Henk
You can use images collected by Kszaq (8.0 and 7.0). The latest versions have all the necessary support for model Tronsmart.
Originally posted by hscotty55 View PostTo do a clean install using SD card/USB drive*and then transfer Libreelec*internal memory: 1. Download file with*img.gz*extension from -> https://yadi.sk/d/srrtn6kpnsKz2/Libreelec . Select the version of Libreelec you want to install. 2. Download the LibreELEC USB-SD Creator -> https://wiki.libreelec.tv/index.php?...USB-SD_Creator 3.*Get a SD card or USB*stick and format it*FAT 32. 4. Insert SD card or USB stick into your computer. 5. Open LibreELEC USB-SD Creator you downloaded from step 2. 6. In the *LibreELEC USB-SD Creator skip the YELLOW number 1 step. Go to the*PINK number 2 step. 7. Click SELECT FILE and navigate to where you downloaded you Libreelec.img.gz file from step 1. 8. In the LibreELEC USB-SD Creator on the BLUE number 3 step select your SD card or USB stick drive. 9. In the LibreELEC USB-SD Creator on the GREEN number 4 step click Write. 10. Once the image finishes writing to the USB stick or SD card click the*CLOSE button to exit the LibreELEC USB-SD Creator. If you see an immediate "Write error" please check the write-protect tab on the SD card. This puts the card into read-only mode and writing will fail. 11. Eject your SD card or USB stick from your computer and insert it into your Tronsmart. Use the toothpick method to boot your Tronsmart. If it just keeps cycling back to the Tronsmart logo and will not boot into Libreelec, unplug your Tronsmart and plug it back in WITHOUT using the toothpick method and it should boot into Libreelec. 12. Verify Libreelec runs correctly from the SD card or USB stick and shutdown your Tronsmart. 13. Take the SD card or USB stick out of your Tronsmart and insert it back into your computer. 14. Navigate to your SD card or USB stick drive on your computer. 15. Look for the file called "install.sh" and rename it to "install.aml" 16. Eject your SD card or USB stick from your computer. 17. Insert your SD card or USB stick back into your Tronsmart and power your Tronsmart on. 18. Wait about 20 seconds and Libreelec files will start copy to your internal memory of your Tronsmart. Process takes about 1 minute to complete. 19. Once install to internal memory is complete, you will have to install all add-ons as your cache and userdata will be wiped.
This package in the link is dated Dec 2016. There is newer version of LibreElec by kszaq. Is there any instruction on how to update to the latest by kszaq?
Just a realignment of the instructions to flash into Internal memory from this post ``Originally posted by hscotty55 View Post``
Select the version of Libreelec (directory "7.0.3.11_test") you want to install.
10. Once the image finishes writing to the USB stick or SD card click the* CLOSE button to exit the LibreELEC USB-SD Creator.
-If you see an immediate "Write error" please check the write-protect tab on the SD card this puts the card into read-only mode and writing will fail.
-If it just keeps cycling back to the Tronsmart logo and will not boot into Libreelec, unplug your Tronsmart and plug it back in WITHOUT
-using the toothpick method and it should boot into Libreelec.
12. Verify Libreelec runs correctly from the SD card or USB stick and shut down your Tronsmart.
15. Look for the file called "install.sh" and rename it to "install.aml" (Note the install.sh is currently available for directory "7.0.3.11_test")
-this process takes about 1 minute to complete.
19. Once install to internal memory is complete, you will have to install all add-ons as your cache and userdata will be wiped.Last edited by e123enitan; 09 February 2017, 17:36.
Hi I have been using libreELEC 009 build for some time on a MXQ Pro 4K box and have been given another of these boxes with exactly the same PCB board. I made another SD card and got the box to boot to LibreELEC but no sound. On investigating I found Audio Device is set to Bluetooth Pulse Sound in Settings Audio output and I can not change it as it is greyed out even in Expert mode. How do I change this setting Please. All help appreciated. Altstart
Originally posted by e123enitan View PostJust a realignment of the instructions to flash into Internal memory from this post ``Originally posted by hscotty55 View Post``
Just one question..Looked back a few pages and I can't see the answer - No Tronsmart remote support ? (LibreELEC Krypton)
Originally posted by Altstart View PostHi I have been using libreELEC 009 build for some time on a MXQ Pro 4K box and have been given another of these boxes with exactly the same PCB board. I made another SD card and got the box to boot to LibreELEC but no sound. On investigating I found Audio Device is set to Bluetooth Pulse Sound in Settings Audio output and I can not change it as it is greyed out even in Expert mode. How do I change this setting Please. All help appreciated. Altstart
Hi balbes, Please HELP I can't get by box to work, I think I have installed incorrect tree or file into the internal hard drive of S905 Tronsmart META, everything was working fine prior to the installed, on the box it display blue light but nothing is displayed into my TV.
I have exhausted the USB approach posted in Tronsmart forum, yet this approach did not work, the box appear to be active, but something is preventing it from being display on TV, this driving
Originally posted by RISCy Dude View PostIf you believe the box is booted and running but not lighting the display. Using a wired USB keyboard, try holding Ctrl+Alt and while keeping them depressed, press and release F5 and then press and release F6 and then press and release F7.
There are currently 2671 users online. 1 members and 2670 guests.
