LibreELEC & OpenELEC for Tronsmart Vega S95
I notice that there is a new file named telos_openelec_mmc_v20160407.img.xz on Yandex.
is this an update of some kind to the original?
Also, is there any way for this to be installed directly to the internal SD as the primary OS so to speak?
The following assumes your error occurs when trying to modify u-boot. Try using this SD firmware.zip (don't extract) with the aml_autoscript (not the file with the ".txt" extension) file to modify u-boot. Place both files on the root of an SD card and the follow the Update&Backup app instructions.
Hello,
I got a 64Gb SDcard. Therefore it cannot be formatted in Fat32. It is formatted in exFat. I don't know if that is the reason but the first procedure failed (telos_update_uboot) with the following screen (see attachement) http://tinypic.com/r/2qx0odl/9
For the first step of the procedure that modifies u-boot, a small card of 8GB or less, is better, Fat32 required. For the second step of the procedure that writes OpenELEC to an SD card, up to 32GB has been tested to work by Balbes150. Some reported using 64GB(I think), but I don't remember where I read it.
There are plenty of utilities out there that will allow you to format your card to Fat32.
Just one example http://tokiwa.qee.jp/EN/Fat32Formatter/
Originally posted by desmondo View PostIs it just me or is it very juddery, I bought a new Kingston ultra fast class 10 card and it keep stuttering unbearable
Two news :
1. bad, I did Telos in the brick.
2. the good news. Found an easy way to restore and the possibility of the make of the modified u-boot. Which will allow you to install to eMMC other systems (Openelec Debian Ubuntu etc). The same can be simplified to run an external system without modifying the regular u-boot. First stage of preparation don't need.
There are currently 1713 users online. 1 members and 1712 guests.
