LibreELEC & OpenELEC for Tronsmart Vega S95
New OpenELEC in and running 5g wifi ok may be channel problem, took a few attempts to connect OK.my 5g use channel 161, 5805mhz
Logitech k400r have lost the use of the Backspace and Del Key (delete) function in OpenELEC.
Backspace on keyboard is acting like Back button on remote.
With Caps Lock on, no numbers across the top, only !@#$%^&*() no 1234567890.
Cheers
Originally posted by trebor View PostSorry to say keyboard still same, also test with hardware keyboard same.
Kodi GUI keyboard still there to use, not major problem.
Maybe optimised for mouse/air mouse ?
Unless other setting in Kodi I am yet to find
Cheers
Has anyone checked the BT ? BT works ?
Originally posted by RISCy Dude View PostHello, WiFi and BT not working on the Meta under v20160417. I only had a minute to check, but no go so far.
The images are universal. You can use the map on the SD and on the USB stick.
I'm in no hurry. Check when you have time.
BT from Telos does not appear to connect,
But the insertion of BT dongle into USB port has detected this dongle,
We now have BT
Make and model I don't know something cheap and cheery from **** I recall.
Connected S3 Samsung phone, not sure what that's all about but connected (don't BT too much)
Found BT Joystick kept on asking to type in code?
Found BT Speaker connected to Sony Sound Bar, settings, system, Audio output, Pulse Default. working well, Remote for Sony sound bar can control OpenELEC basic FF/RW etc
Found BT on TV that's about 6 meters away in another part of the house.
All good with external Dongle.
Cheers
We now have BT
Cheers
There are currently 2341 users online. 0 members and 2341 guests.
