Please check universal image from SD card and USB flash drive.
LibreELEC & OpenELEC for Tronsmart Vega S95
I am having trouble getting past the openelec boot logo. I have used 4 different cards, 3 are known to work for telos odroid ubuntu and the previous meta image.
I have tried several times. I have reviewed the procedure and started with all freshly download files.
I will try again tonight. Not sure where I am going wrong.
Sorry for the delay. It is working well now, from card slot and USB card reader. I don't have a suitable flash drive to test on at the moment.
The WiFi is working very well at 2.4GHz, don't have 5GHz here.
Bluetooth displays "no device", but as Trebor stated, USB BT dongle works. Other than the on-board BT not working, it seems to be perfect so far.
Excellent work balbes150.
Update the DVB-S2 driver to join s662 tevii support thanks https://patchwork.linuxtv.org/patch/33281/
Originally posted by youpai View PostUpdate the DVB-S2 driver to join s662 tevii support thanks https://patchwork.linuxtv.org/patch/33281/
Added to the website for the Pro model. pro_openelec_v20160419.img.7z
Originally posted by youpai View PostChange the kernel to join the patch? thanks https://patchwork.linuxtv.org/patch/33281/
Originally posted by balbes150 View PostTo use this patch, want the core 4.x . Or you need to look for all the patches associated with these changes. I will try to test a few options that would implement it.Last edited by youpai; 24 April 2016, 00:25.
There are currently 1957 users online. 3 members and 1954 guests.
