HPH NT-V8 ROM V1.4 by mo123
    HPH NT-V8 ROM V1.6 by mo123
    http://www.multcloud.com/share/fecca...b-28f19208f71f
    Pass: nagrace
    * New Launcher
    * Updated NTMC Kodi
    HPH NT-V8 ROM V1.5 by mo123
    Fixed Weather Info in Launcher
    Updated NTMC
    Fixed Seeking in RK Video Player
    Fixed Audio out of sync issue
    Removed stock apps and replaced by alternatives
    Faster navigation in menus
    Stutter Fixes
    Added language strings to launcher, RK Video Player, Settings
    Download Link: Here
    Pass: nagrace
    Flash Tool & Drivers: Here
    NTMC Kodi
    - Fixed aspect ratio problem with videos
    - Correct Audio Pass-through settings are set by default.
    Users just need to enable their correct AC3/DTS/HD audio settings in NTMC's Audio Settings and set 'HDMI Bitstream' Audio Setting in Android Settings for pass-through to be in sync.
    - Disabled unnecessary options
    - Added External Player support for MXPlayer and RKVideoPlayer
    When using an airmouse, hold in the left mouse button over a video or stream link, a menu will then pop up.
    Choose 'Play using'
    Press the OK or Select button to choose it.
    Then you can choose to play the video with MXPlayer or Stock Video Player.
    You can also press the letter 'c' on a video link to bring up that menu if you have a Bluetooth/USB keyboard without a left mouse button.
    In MXPlayer you can press on the top right settings menu, choose display, aspect ratio to change the aspect ratio of a video.
    There are quite a few to choose from 21:9, 16:9 etc, that might help.
    In Stock Video Player you can bring up the menu by pressing the 'menu' button on the IR Remote.
    You can then change the aspect ratio, subtitles, audio track and some other options.
    - Added Display Color Changer for people with Green/Purple screens on old Sony & Phillips tv's.
    Choosing a different color setting eg. RGB 255 will solve the problem.
    The setting stays after a reboot so no need to change it again.
    - Fixed stutter with USB Audio
    - Removed the battery menus
    - Added stock launcher, can select it instead of HPHLauncher when device starts for the first time or in 'Home' in Android Settings
    - Improved color, denoise
    Download Link: Here
    Pass: nagrace
    HPH NT-V8 ROM V1.3 by mo123
    - New NTMC Kodi 16.1 with standard Audio API support
    * Framepacking 3D
    * HDMI-24hz Bluray 3D
    * Auto Switch HDMI-3D Bluray 3D
    - Fix sound problems with games
    - Fix touch sound bug
    - Improved USB stability for connected devices
    - Casting/mirroring support
    - Fix ES File Manager black background
    - Fix the Dolby Digital Plus problem
    - USB webcam mic fix
    - OK Google support
    - New Security patches
    - NFS/NTFS support
    - 'Lacie' hard drive support
    - Universal storage(around 12.8GB)
    - IR Remote with automatic key repeat
    - RKGameControl app included
    - 1080p/1440p Youtube
    - Google Movie support
    - MXPlayer with DTS/AC3 Codec
    - Audio sync improved
    - Fix random ethernet MAC
    - Various ethernet & video fixes
    Click image for larger version  Name:	hph_launcher.jpg Views:	1 Size:	37.7 KB ID:	578536
    To Root
    Go to Accessibility options
    LeHome Assistant
    To enable Remote Control support and casting
    Install 'Le Home Assistant' from Android Settings menu.
    To use the mira-cast feature
    1. Go to Display Options - Casting and enable 'Wireless Display' option from the 3 dots menu
    2. Do the same on your phone.
    3. Now connect to your tv box id and it will connect.
    Both devices should be connected to the same wifi network.
    Code:
    [COLOR=#006400][U][B]Correct Pass-Through Settings for NTMC[/B][/U][/COLOR]
    Android settings
    -Resolution is set on AUTO
    -Frame-rate sync ENABLED(might not be available)
    -Color space is set on AUTO(might not be available)
    -Audio - Set to 'HDMI Bitstream' not 'Default'
    [COLOR=#0000cd][U][B]NTMC settings[/B][/U][/COLOR]
    -Playback - Adjust display refresh rate - Always
    -Pause during refresh rate change - 11 seconds or lower, use what's best for you
    -Sync playback to display - On
    -Acceleration - Allow hardware acceleration MediaCodec - On
    -NTMC Settings - Accelerate RKCodec - On
    -System - Audio output - Play GUI sounds - Never
    -Enable pass-through - On
    -DD/DD+/DTS/TrueHD/DTS-HD - On
    Here is a spreadsheet with Audio Receivers with best settings to use and what works.
    [URL="https://docs.google.com/spreadsheets/d/1s2q_-X0owW9xVtqTIEpprxDsM_ZhXtDYfAPQ2CtzHno/edit#gid=1685174283"]https://docs.google.com/spreadsheets...gid=1685174283[/URL]
    Code:
    [U][B]Instructions:[/B][/U]
    [COLOR=#008000][B]Before Installation[/B][/COLOR]
    - Make sure USB Power saving mode is disabled for the USB Port you use to flash the device
    - Use a PC Back USB Port and not ones from the front or a laptop
    - Pause Antivirus software for 10 minutes to not interfere with the flashing or cause high disk usage.
    - Make sure device was connected to PC before in flash mode and drivers were installed
    [COLOR=#0000ff][B]To Install the drivers[/B][/COLOR]
    1. If flashing for the first time, you need to install the drivers with DriverInstall.exe
    2. If you recently upgraded your operating system to Windows 8.1 or higher, it's also a good idea to install the latest drivers.
    3. Let your PC recognize the device and automatically install the drivers
    - Connect the device with an OTG Port and cable to PC
    - Now connect the power adapter
    - Before plugging the power adapter into the device, hold a paperclip into the reset hole of the device, keep holding it while connecting
    the power. You will hear a 'click sound' that Windows has now recognized the USB device.
    - It will ask to install the drivers or install it automatically.
    [COLOR=#ff0000][B]Flashing the ROM[/B][/COLOR]
    1. Select 'Upgrade Firmware' in AndroidTool v2.35(Second tab)
    2. Click on the 'Firmware' button to load the firmware(update.img that you extracted from the 7zip compressed file)
    3. Click 'EraseFlash' to wipe your device, wait for it to finish.
    4. Click 'Upgrade' to flash the new firmware.
    5. Wait about 2 minutes after flashing and before unplugging device for firmware to settle.
    6. Disconnect from PC and connect to TV.
    Firmware works on Nagrace HPH NT-V8 devices and also Ugoos UT4 RK3368 tv boxes.
    Download Link: Here
    Pass: nagrace
    Will this firmware work in my android tv'¿?
    If i fans it...can i go back with original firmware?¿?
      You can try but I don't think wifi will work and also not the IR remote.
      You can use an airmouse or USB keyboard/mouse.
      Just make sure you have a backup firmware of your device to flash back if you plan to try it.
        ok...thanks for your answer..i will think about pro and contra
          screen looks cool.
            I'm so Sad... No work on my Tronsmart R68
            - Navigation Menu, is Slow... (have reboot 3x, and power off 3x ...no result same Menu faster firmware 1.2 Dual Boot..)
            - Launch App, is Slow, and App no Work very good.. have text display "wait or close app" only.
            - NTMC no Start ... text display only "wait or close app" ( old NTMC firmware 1.2 have same message but work after..)
            - POWER ON boot after 2 minutes or 3 minutes...
            - Ethernet, NO WORK...
            TRONSMART R68: Firmware "HPH NT-V8 ROM V1.2 (Dual-Boot) by mo123" (DTS-HDMA, Work)
            ONKYO: TX-NR 809
              Thank you very much!
              kind regards
              cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
              http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
                Thanks Mo 123. I am going to try this. I was very happy with version 1.2 but unfortunately most harddisks weren't seen otherwise i would have keep using it. Thanks a lot for all your work and help!
                  - IR Remote with automatic key repeat.
                  Hi mo123,
                  Does it mean the long press feature as well? Doesn't it belong to the IR remote construction? I have two remotes, both send the same codes, just one (Tronsmart) sends them continuously, while the other (looks the same as of the Ugoos remote) seems sending single codes only.
                  Regards, STZO
                    Originally posted by Stzo View Post
                    Hi mo123,
                    If you hold in the arrow/direction keys it will automatically keep running instead of you having to press the same key multiple times.
                      How do I edit the main screen to give me local weather?
                      kind regards
                        i tried to flash twrp but when i try to enter recovery it freezes .... i have a r68g box which i have flashable kernel for it so please tell me how do i flash my kernel or can u built this to work for r68g?
                          It only works on Nagrace HPH NT-V8 and Ugoos UT4 devices.
                          For Tronsmart there are several other custom firmwares you can flash.
                            Small update
                            - NTMC Kodi updated
                            - Color Changer for people with Green/Purple color on old Sony & Phillips tv's.
                            See OP for complete changes.
                              The weather API expired, that's why the weather didn't work in the launcher anymore.
                              An update will be released soon to fix it.
                              I think the launcher will have to be updated for that but will let everyone know and release a new firmware if needed.
