HPH NT-V8 ROM V1.4 by mo123
Hi mo123 Will you be building a 6.01 release for the NT-V8?kind regards
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
I will try to make MM firmware for the HPH NT-N8(ARM) soon.
Then I can see how it goes and report all the bugs.
Later I might try for the HPH NT-V8(ARM64).
There is a problem with DTS codecs in MM at the moment, so I just want to find out how it's going to work.
Lots of videos require this and will have no sound without this.
Then also have to find new 'root' methods etc.
Also have to get new sources so all the bugs are fixed, otherwise will need to use older buggier ones that were more for tablet use.
Stable MM will be released for RK3399 soon and later backported to RK3288 then probably to RK3368 too.
kind regards
You can also try the link below
This firmware also works very well and has Netflix audio in sync(I haven’t fixed that yet in my firmware)
kind regards
mo123 Ho Mo123, please could I pick your brains again?
How do I replace the NTMC on the launcher with KODI 17?
How is the Marshmallow release coming for this box?
kind regardskind regards
Thank you mo123 ! I will be looking out for the new firmware! Your stuff ROCKS!kind regards
Originally posted by gefattern View PostHi Amoren ,
Yes,try
i use it on my UT4.Thanks to Mo.
nice Day
gefattern
Please let me know the steps.
Originally posted by ontherocks View Post
What tool do I use to install this TWRP?
The ports are exactly the same.
Just substitute the firmware file from here, previous posts also contain a mega link for the firmware.
There are currently 2851 users online. 1 members and 2850 guests.
