HPH NT-V8 ROM V1.4 by mo123
    Originally posted by shivattaque View Post
    After more testing and especially with your samples, I realized that everyone was working:
    DD, DD Plus, DD True HD, DTS, DTS HD MASTER.
    I did not test long enough to see if there is any cut but everything goes. But the problem,
    because there is one, Is that the can not move the time cursor without freezing the image
    or shifting the sound it has to look at everything.
    I do not know that option does that.
    You can go to NMC Settings - NTMC - RKCodec - Disable this setting then seeking can work properly.
    Please check if pass-through is still working then, but it should.
    Did you test the new v1.4 RK3368 Marshmallow?
    I need some feedback from users if pass-through is working there.
    One user said SPDIF pass-through is working but I don't know about HDMI pass-through.
    If there is a bug, I need users to test some things.
        You mean 1.1 RK3368 Marshmallow
          Yes, v1.1 Marshmallow you can test.
          But the setting in NTMC to forward/rewind, seeking in videos can work in both Lollipop and Marshmallow when you disable RKCodec.
            yes and I found the menu to activate the passthrough then I opened kodi and configured for the passtrouth (HDMI) I also try FTMC but it does not work.
            Terrible acute noise.
              OK, I will make a new bootimg that you can flash later to test the pass-through again to see if it makes any difference.
                Sorry to bother you with this, but you have a solution for the scaling problem (screen scale) on your rom 1.6?
                And concerning the remote control problems, is it possible to take the resources or at least part of a rom in which it works like Ionix 9.5?
                  I just saw another scale problem, on the 720P video in Kodi NTMC, I have a black band at the bottom of the screen, except when I let the RK accelerations on, but there is a loss of synchronization and Graphic bugs once and of course I can not advance in the timeline.
                    For Marshmallow v1.1, do you also have screen scale problems?
                    Can you upload a picture of Android Settings - Display - Scale with the 4 arrows set to maximum screen zoom, so I can see the black borders on the tv?
                    Use the screenshot icon at the bottom of the screen to help.
                    NTMC on Marshmallow also should work well with no black band at the bottom and you can also seek in online videos with RKCodec turned on.
                    Audio synchronisation is much better on Marshmallow.
                    I'm working on improving the scale and pass-through on v1.2 HPH MM firmware.
                    I won't be supporting Lollipop v1.6 firmware any more as I deleted the project.
                      I tried Kodi 18 Nightly Master built and it's good for the scale problem 720P on 1.6.
                        After several tests I can tell you that, this is the best ROM I tested for HDMI bitstream: DTS, DD, DD Plus, DTS HD Master, Dolby Digital True HD. OK.
                        The problems that I had related to the scale of the screen and some 8 bit stereo manga that I can read with MX Player but that worked on other ROM,
                        so one day everything will work I hope.
                          mo123, my screen saver will not work. When I check the box then back out it resets and does not save. How do I get the screen saver to work? This is the only firmware that fixes the global stuttering of my i68g. Your help is much appreciated.
                            how can i unpack this ROM ?
                              Hi ,
                              if u mean the downloaded FW , u need a Unzipper , like 7zip and others ...
                              do not forget the password : nagrace / i think it is right / look first post
                              good luck / gefattern
                                Hi ,
                                i mean the .img file
