there is a version with a non-working remote control?
HPH NT-V8 ROM V1.4 by mo123
Do you mean unplug the power cable and then press the hardware power button to turn it back on?
If the firmware is used on a non HPH NT-V8 or UT4 RK3368 device then there will be problems with the power since these devices use completely different power chips and drivers than other RK3368's.Â*
In most cases short press the power button makes it sleep.
Long press the power button then you can power it off completely, then you need to use the hardware power button to turn it back on.
But I'll just check the sleep setting in Marshmallow and how it works.
kind regards
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
Originally posted by natzen View PostPossible to your futur firmware work on zidoo x6 ?
If the firmware works on other devices great, if not there is nothing I can do.
Zidoo should learn to support their devices instead of wanting to let users buy a new device every time a new Android OS comes out.
X6 - Lollipop still with a lot of bugs, X9S Marshmallow still with a lot of bugs, to get Nougat you will need a new device again.
Rockchip already made Nougat firmware for all their devices, it is just up to manufacturers to make an effort to get it from them.
Originally posted by mo123 View PostHPH NT-V8 RK3368 Marshmallow firmware released
Please see the new thread
http://freaktab.com/forum/tv-player-...w-rom-by-mo123
official rom for ut4 work great on zidoo
I tried your rom 1.6 it's good job. But on my i68G impossible to exit standby with the remote control and the light stays blue instead of being red, No BT/Wifi. i test ntmc : Impossible to advance in the time of the video, it blocks. With Ftmc that ok, this is only my first try with a manga 720p 2.0.Last edited by shivattaque; 17 February 2017, 07:03.
The video isn't 10-bit h265 right since the RK3368 doesn't support that.
Seeking in online videos work in RKMC if you use an airmouse, it takes about 5-7 seconds to kick in or you can use Kodi 17 64-bit with Mediacodec acceleration that should work better for non 4K videos.
Unfortunately I spend days just to get the IR remote working and impossible to get it working for other devices since I don't have time and it's too complicated without the manufacturer's help.
For everyone using a tv box, get a cheap $10 airmouse and it will make a huge difference.
There is also Quick Reboot app from the Play Store that helps with shutdown for a couple of different devices.
Thank you mo 123 but it works well with FTMC. I'm going to watch movie tonight after the job to see if all works in passthrough.
For the remote control I have the one:
And it worked on the fimware Ionix 9.5
It is not the prettiest but it works well.
ps:38747 antutu.
After several test the remote control works but after 5 second the box does not wake up.
Otherwise, the led remains blue.Last edited by shivattaque; 20 February 2017, 22:01.
After more testing and especially with your samples, I realized that everyone was working:
DD, DD Plus, DD True HD, DTS, DTS HD MASTER.
I did not test long enough to see if there is any cut but everything goes. But the problem,
because there is one, Is that the can not move the time cursor without freezing the image
or shifting the sound it has to look at everything.
I do not know that option does that.
I just noticed another small problem concerning the display or rather the resizing of the android display,
indeed the display does not take up all the space of my screens.Last edited by shivattaque; 25 February 2017, 18:16.
There are currently 2514 users online. 0 members and 2514 guests.
