Another problem is , that current Nexbox firmware don't boot to USB burning or SD card boot.
Purchased Xgody X96 2G/16G from ****.
Originally posted by hikka View Post
I flashed to my X96 box Nexbox A95X firmware with SD card method. Sadly I don't have img file of X96 stock firmware. Can you share yours?
After that flashed customized EBOX Q firmware, that seems to be better, than original X96 firmware.
Now trying to make better customized firmware with AML firmware customization tool.
Finally managed to get back my X96 features for USB burning tool. I had manually write correct recovery, boot, bootloader and dtd .img images.
Can you share the file?
Originally posted by Bmsone View Post
How did you convert them? Need .img file for USB Burning Tool since i tred wrong firmware and lost remote.
Unzipping update file you got .img files.
I did write with terminal emulator commands.
Using shell:
1. Copy recovery.img to your internal storage, external SD card, or USB stick
2. Open e.g. Terminal Emulator and change into the directory you saved the recovery.img (/sdcard, /storage/sdcard1, or /storage/udisk0, respectively)
3. Execute following commands
su dd if=recovery.img of=/dev/block/recovery
For X96:
Shenzhen Tomato X96 firmware: https://pan.baidu.com/s/1b0PCrc
password:hp7u
Select 2G / 16G RTL8189 firmware , if you have this wifi chip.
Direct link to firmware:
https://pan.baidu.com/share/link?sha...ath=%2FAmlogic
Downloading firmware was tricky for non chinese, but Google helps.
Sorry , don't have files anymore. But if you can download SDcard update file for your HW (mine p212).
Using shell:
For X96:
password:hp7u
How do i download from baidu? Cant register there... Think that is the right firmware,
Yes, but the install from SD fails. saying the file is corrupt. Downloaded it several times
If I remember correct, I did get my SD card /USB flashing back with those files.
SD card update is not working , because you have wrong firmware and dtd.img partitioning.
Writing those would repair it.
There are currently 2120 users online. 3 members and 2117 guests.
