Purchased Xgody X96 2G/16G from ****.
@scoooter2014 and teverz
i think i have the same board because i have the same issues that if i flash another image the board ecomes a 1gigabyte one
the image that teverz posted helped me a lot it is the x96 image with vincent@ubuntu kernel his is 20161220 i got a box with 20170214 firmware with vincent@ubuntu kernel
and what i expected happend the image with the vincent kernel shows 2 gig
als other versions and libreelec and armbian says it is a 1 gigabyte board
and it is not that you flashed the wrong firmware so as you both suggest it is HARDWARE and the hardware says 1gigabyte of memory
open your box and see what kind of memory chips you have like mine has h5tq2g63dfa wich are 2gigabit chips and 4 in total is 1 gigabyte and not 2 what the vincent build says
so you are also counterfeit by the seller just check the hardware and you notice .
and i think 90% of the people are scammed because you only notice it if you want to update or mess with it a normal customer don't notice
You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
I checked board 2 gig did program check on memory is 2 gig 16 gig but flashing make 1 gig. Run ram truth then 2 gig firmware installed shows correct. But mine board may be damaged because nan poor soder only show 2 gig 8 gig no longer 2/16. I post firmware i get to return to 2 gig with.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
yeah just check your ram modules i bet they are 2 gigabit instead of 4 gigabit
4x 2 gigabit is 1 gigabyte and 4x4 gigabit is 2 gigabyte was the same mistake i did
just put a librelec or armbian image on sd and boot from that and that says 1 gigabyte
or play with the dtb's only 1 gig dtb boot from sd if you put a 2 gig dtb on it won't boot
already checking in wich module the fake is done i think in uboot or the ddr.usb file
the image teverz posted is the tempred image wich shows 2 gigabyte
and if you put one from another x96 like a 1.09 or 1.1.1 from other sites it shows 1 gigabyte wich it is in fact
and you have to do a full image burning with usb burning tool because the other images doesn't have partion 8 what the fake 2 gig version has it is the dev/tee partion
so that is why you have proplems to flash other images on it
yeah got that one is same as teverz posted with the vincent@ubuntu kernel that is modified to show 2 gigabyte instead of 1 gigabyte
check the ram
https://www.skhynix.com/eolproducts....19&rc=consumer
that is just 256mb so x4 is 1 gigabyte
that is picture of my ram it is 2 gigabit aka 256mb
that is the hole fun how did they fake the memory i think it relies in the kernel
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by shaggy013 View PostYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
ah and i see that you also have the 20170214 image from seller
i think that your scammed also
take the backplate open en see what memory chip you have i think it is 2gigabit wich make 1 gigabyte
just flash a 1.09 or 1.1.1 x96 or put a libreelec or a armbian image in your sd and toothpick to boot from sd and let me know how many memory you then get
Thanks to everyone who has contributed to this thread so far. I'm new to the forums but I've been a computerguy since installing Windoze 95 from floppy!
I just purchased two X96 2g/16g boxes from newegg (sold by hengling) but I haven't received them yet.
I have read through all 9 pages of this thread and it seems like most problems I'm reading about come from flashing problems rather than native issues. I'm wondering first, why is there a need to flash the ROM?
Will I be able to use Es Explorer to get root access in order to delete the bloatware and pre-installed kodi without flashing the ROM?
At this point, if I do have to flash, I'm not sure which ROM to use. Can someone "sticky" the ROM that is most agreed to work best on the X96? If there are different ROMs based on the various warehouses these things are manufactured in, maybe a sticky post with a handful of finalized ROMs and some info / how-to on each?
And lastly, just to be clear, am I reading correctly that the 2G/16G units actually only have 1G (scam)?
Thanks in advance. I hope to have something to contribute once my units arrive.
I found this thread in an attempt to find some info / how-to on upgrading to Nougat
There are currently 1703 users online. 0 members and 1703 guests.
