LibreELEC 7.0 For S905/X (old)
Image uploading here sucks (tiny thumbnail) . But I see what you mean.
What version did you flash?
The latest version is this one: http://freaktab.com/forum/tv-player-...113#post602113
Originally posted by alleyrm View PostThat's the version I flashed. Had to download from the mirror though
This version is stable but missing a few features. Mainly h264 4K, but HEVC is fully working.
LibreELEC-S905.aarch64-7.0.2.007.zip
You need to unzip and flash the LibreELEC-S905.aarch64-7.0.2.007-update.zip
Just to make sure there isn't anything else that maybe messing up the install. Restore the original firmware first: http://www.tvboxnews.com/nexbox-a95x...ware-download/
Than flash the LibreELEC-S905.aarch64-7.0.2.007-update.zip with TWRP.
That build does work with your box: http://freaktab.com/forum/tv-player-...054#post602054
Update.
Again this is for Boxes using the S905X SOC with 2GB of RAM.
LibreELEC-S905X-gxl_p212_2g-2016-10-11.zip- You can now play Jellyfish test videos up to 400Mbps.
- 4K H264 videos are now possible.
Originally posted by bluesmanuk View PostDidn't work on my TX5 Pro, even after flashing stock firmware.
All that happens on boot is that you get the S905X logo and nothing more.
Originally posted by pinguy View Post
Had a guy on another forum that had the same issue. He had to format his data partition.
Taking the SD card out and attempting to boot into recovery from the stock ROM doesn't work either, so maybe an issue with recovery in stock.
Will try another firmware.
Anybody got a link to the Nexbox A5 stock?
Thanks for the link.
I used this firmware and had no issues: https://mega.nz/#F!QtozVLyB!kZ-PB9VtLn-RUY1rJGZExQ
It is for the YUNDOO-Y6 32GB version but it worked fine on the Nexbox A5 2/16.
EDIT#
Anyway, this is where I get my firmware from: http://www.tvboxnews.com/category/firmware/
For the Tanix TX5 Pro you can get it from here: http://www.tvboxnews.com/android-mar...-box-download/
Nexbox A5: http://www.tvboxnews.com/android-6-0...x-a5-download/
NEXBOX A95X (S905X): http://www.tvboxnews.com/android-6-0...x-a5-download/
I am running this on the Nexbox A5 16GB version.
Sadly that did not work either.
It will not boot to TWRP from the SD Card and have tried 4 different cards now too.
Last edited by bluesmanuk; 12 October 2016, 12:19.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Cheers.
Not sure if it matters. But I used a 16GB card. 16GB and under should work fine. 16GB and over can be a bit of a nightmare. Some old card readers can't read cards larger then 16GB.
Yes I renamed it.
Did the USB flash drive thing too, which flashed and nothing else on the SD cards (FAT32 formatted), so no idea what the problem is but will give it a miss for now until somebody else gets it working on the TX7 Pro.
EDIT#
This guy got TWRP onto the TX5 Pro. Its the same one I linked to.
http://freaktab.com/forum/tv-player-...595#post594595 Post 19
Also never tried. But have you tried putting TWRP onto the USB Flash Drive? No clue if it will work, but no harm in trying.
There are currently 3495 users online. 3 members and 3492 guests.
