LibreELEC 7.0 For S905/X (old)
I have a COOLEME (Mini M8S II) and i installed LibreELEC 7.0 to a Micro SD Card, created a dummy.zip file .... and my box Boots straight to LibreELEC without having press any reset buttons
Pretty happy with this as i can exit Kodi using (Reboot From NAND) and the Box will reboot to Android ... so i can play games, netflix etc etc
Then using a Reboot App (from the Google Play Store) ... reboot, and it boots back to LibreELEC (this is ideal for me as want both OS's ... so i'm not gonna install LibreELEC to NAND, SD Card works fine)
this is the version i'm using:
http://kszaq.libreelec.tv/s905/devel/2016-10-03-devel/LibreELEC-S905.aarch64-7.0-devel-20161003204518-r23361-gb5788b7.img.gz
Originally posted by pinguy View Post
Might not be ideal but until you can find the PC Update .img CEC is fully working. Most TVs do have this feature.
Originally posted by bluesmanuk View PostOne thing that I have noticed and which has also been shown to be the same with the S905x Android firmwares is that the videos are all a little too dark and therefore don't reproduce colours as they should be seen.
A good way to show this is to play this file.
Diese Website steht zum Verkauf! demo-uhd3d.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf demo-uhd3d.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
On a box with correct reproduction such as the Dolamee D5, the colours are vivid and deep, with black levels correct.
On the S905x the colours are dim and overshadowed by the black levels that prevent a lot of the colour from being shown.
Brightness 75%
Contrast 40%
Fixes it, but that is odd. Is it just because that video is dark because it is a demo for OLED TVs??
Are there any other video formats that dark? Or is it just that one?
All the videos I have played have not had the issue of being dark.
Settings:
Brightness 75%
Contrast 40%
All formats are not quite right and that demo was just a good example of where it is extreme.
When comparing to how it should be it is definitely sub par.
That is not to say that it is not eminently watchable but the difference is noticeable.
But with the same thing being the case on all Android firmwares, I think that it will be a case of waiting for SDK improvements.
I already tried playing with brightness and contrast.
I just tested it with them settings and it looked fine. When you say you played with the brightness and contrast. Are you on about on the TV or within Kodi? The settings I posted was for Kodi.
When I get a few minutes I'll capture some footage from the D5 and the TX5 Pro that will show the difference.
When the brightness and contrast is adjusted there is more of a washed out effect and greys are not quite right.
In Kodi.
That video you posted is the only one I have come across that is dark. And just bumping up the brightness and slightly lowing the contrast within Kodi fixed that. I honestly think it is just that video unless you can show another example.
I use this for my tests: http://jell.yfish.us/
I'll capture some footage from each box so you can get an idea where I am coming from.
I can show it on a few videos.
EDIT#
I am just downloading a few Ultra HD videos with HDR. The issue might be with HDR videos, but need to test.
It's not just HDR.
When playing an HDR video, if a TV doesn't support the HDR layer then it will just ignore it and play the underlying stream.
But I'll sort out some comparisons tomorrow where difference in colours and also detail can be shown.
Pretty sure the issue is with Rec. 2020/BT.2020.
EDIT#
This needs to be added: http://forum.kodi.tv/showthread.php?tid=254875Last edited by pinguy; 14 October 2016, 02:55.
Hey Pinguy, did you test the 7.0.2.008 already yourself? I'm trying to grab it from http://kszaq.libreelec.tv/s905/7.0.2.008 but the link seems to time-out. and I need the original one from Kazq
There are currently 3512 users online. 3 members and 3509 guests.
