LibreELEC 7.0 For S905/X (old)
Originally posted by pinguy View Post
I have the same box and install to internal nand flash using the method posted in the first post.
EDIT: What I do.
I install TWRP-LibreELEC-S905X-2GB-7.0.3.011.zip to the Nexbox A5 internal nand flash using TWRP recovery that I have placed onto a 16GB SD card (holding the reset button while booting boots into TWRP). Then flash TWRP to the recovery.
Once LibreELEC 7 is installed (warning this will wipe Android) I use this wizard to install a Kodi build (more info at the facebook page). I just place the wizard onto the SD card and run "install addon from zip" than find the zip.
You could FTP to the box and place it that way. But it doesn't really matter. You just need to install the plugin.video.Oxygenh20wizard.zip
Once it is installed run the wizard from "programs" and hard restart.
otr
Next place this file into the .config folder to get the remote working.Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
Just got T95X 2GB x 8GB . Loaded Librelec 7.0.3.001
Runs like a dream
boots completely in about 10secs (maybe less)
video runs smooth from SD to 720 to 1080. (measy b4ts would constantly do bunch of black/blue screen display screen refreshes )
audio runs great through stereo.
Cheap price but top notch speed/quality !!
Hightly recommended
pinguy thank you for your effort!!!
Anyone else having problem with the subtitles services? There is no option to add any of them. Furthermore, i cannot find the PVR addons in the settings. I would like to use IPTV Simple PVR. Any suggestions?
edit: both the subtitles services and the PVR addons are on the settings-->addons waiting to be installedLast edited by katsikaki; 06 January 2017, 19:30.
Hi Hez13 ,
sorry i dont know much about Kodi or the addons.
maybe this helps :
https://www.tvaddons.ag/kodi-addons/...rebootandroid/
good luck
gefattern
There are currently 2475 users online. 0 members and 2475 guests.
