LibreELEC 7.0 For S905/X (old)
warlock0901 I cannot say that using usb works. Also the description you gave is not good enough. You need to know if you have 1g or 2g of ram. You also need to know if you have a s905 or s905x. That matters. To boot from sd you have to extract the libreelec contents to the sd card and then boot while holding the recovery button. Honestly, your best bet would be to follow the instructions provided by the OP. If your unsure if you like it then make a backup to your sd card. This way you can restore it back if you dont like it.
Originally posted by Urgodfatherwarlock0901 I cannot say that using usb works. Also the description you gave is not good enough. You need to know if you have 1g or 2g of ram. You also need to know if you have a s905 or s905x. That matters. To boot from sd you have to extract the libreelec contents to the sd card and then boot while holding the recovery button. Honestly, your best bet would be to follow the instructions provided by the OP. If your unsure if you like it then make a backup to your sd card. This way you can restore it back if you dont like it.
Originally posted by pinguy View Post
Yeah that is my bad for not fully testing. I put in a untested dtb.img and it broke the reset button. To fix grab the latest tree from here and place it into the 'update' folder via FTP.
bitfed you don't have to use my file. I will be glad to take it down. Download pinguy 's file. Open it with 7-zip and replace the dtb. Just a FYI, I hope you have the original firmware and amlogic tool to restore your box b/c I won't be sharing my backups anymore.
Word to the wise, you really shouldn't make implications about the guy offering help... especially where he can see it. Smooth move Ex-lax.
For others who wish to use my file, need firmware, etc. I will be happy to share. You will need to contact me for a decryption key though.
Been using Libreelec on my TV Box TX95 2g 905x.
Works really good in almost all aspects. Especially the multi channel audio through hdmi.
I've been comparing this to Xanny Tech's modified firmware. Way better than my stock rom. That android system still has problems playing DTS music files that are encoded at 44.1khz. They play as stereo files that just have a hissing sound. It also doesn't understand Dolby Digital Plus or Enhanced Dolby Digital (same thing). No sound at all.
Libreelec plays theses perfectly.
Now what I'm seeing on the Libreelec side is this. When the TV Box is powered down, my USB drive keeps going and doesn't power down and go to sleep. Does anyone else have this problem? Is it a known bug?Last edited by Woogetybop; 12 August 2017, 04:51.
None of the device tree files work, I tried all of the 2g files, but no luck. I place them renamed as dtb.img in the update folder and then reboot and I get this on the boot screen
"upgrade in progress... Please do not turn off device... found new image file... could not find a valid system partition in image file"
Is there any other way to fix the device tree? I'm on a Nexbox A95x s905x 2GB
Is anyone able to repack a firmware as a img.gz with the dtb.img that I need so that I can put in my update folder and fix it from there?
I can place a new build into the update folder (LibreELEC-S905.arm-8.2-8.1.4.img.gz)
from here http://kszaq.libreelec.tv/s905/8.2/8.1.4/ and it updates, but I still can't get recovery from there. Updating this way is working at least, and my wifi is now working (wasn't with pinguy's file)
Any help would be greatly appreciated
Yeah I tried that as well but it still didn't get my recovery working again. kszaq replied to my post on libreelec.tv saying that 'You can't have LE on internal memory and working recovery at the same time'
So maybe this is my problem. Am I better off running the box with android on it and just getting it to boot to libreelec on the SD card?
I guess the tricky part now is going back to android without a recovery...
I better go get that usb cable you mentioned Urgodfather
There are currently 1702 users online. 0 members and 1702 guests.
