Edit. Found it. Was using too big of a toothpick to make it click.
LibreELEC 7.0 For S905/X (old)
Originally posted by sandog View PostDoes anyone have stock firmware for a nexbox A5.. I am using none stock firmware and i cant get my box to read the recovery.img to flash
Originally posted by pinguy View PostAs LibreELEC is the way forward with these Boxes as the supplied Android image is pretty much garbage, I have made an update for all S905/X Nexbox's with 2GB of RAM.
LibreELEC-S905X-gxl_p212_2g.zip
This is based on the 2016-10-03-devel version.
All I have done is included the dtb.img. Without it HD audio won't work and gives the crackling sound. I have also replaced the Nexbox boot image with the default Amlogic S905X boot image.
To install just flash with TWRP.
This should work with:- Tanix TX5 Pro
- MINIM8SII
- Nexbox A5
- Nexbox A95x
- COOLEME MB1
Guys why don't you try first the SD Card way and then decide what works and what doesn't ?
This way your box will remain unaffected and you can test what you want.
(And if you have a fast Class 10 microSD card, there is no real need to install LibreElec on the box's NAND).
Note: only 1 USB port is able to boot the box. You have to try them all. Some boxes are unable to boot from USB drive.- Look at the beginning of this post and find Downloads link. Download file with img.gz extension.
- Burn the downloaded file to SD card or USB drive using Rufus. Alternatively you can use LE tool but remember that you have to download the image manually: http://wiki.libreelec.tv/index.php?title=Installation
- After this you will see that drive capacity is 512MB. This is OK as there is a second (hidden) partition on the drive for LE user data!
- Download a device tree, rename it to dtb.img and copy it to main folder of SD card/USB drive - replace the one that's already there.
- To boot the system for the first time you have to use one of the following:
- toothpick method: disconnect the power supply, insert card/drive, push reset button and connect the power while holding the button. Wait until LibreELEC logo appears and release the button.
- menu button method (works with very few devices): disconnect the power supply, insert card/drive, push menu button on your remote control and connect the power while holding the button. Wait until LibreELEC logo appears and release the button.
- recovery method: boot into Android, insert card/thumb drive and choose Reboot to recovery. Your box should boot into LibreELEC.
- recovery method (2nd variant): if you have "Update" app pre-installed open it, insert SD card with LE/connect USB drive, and choose any ZIP file in the app for update. Your box should reboot to LE.
- recovery method (3rd variant): if your box is rooted, use terminal emulator app and execute reboot update command
- recovery method (4th variant): enable ADB (Google it) and issue adb reboot update command
Originally posted by zerocool99 View Posti really wanna try this image but on my tanix txpro 905 x, but it look like right minefield, its it better that the frankinstein image that i currently have
thanksMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 3942 users online. 0 members and 3942 guests.
