LibreELEC 7.0 For S905/X (old)
kage000 I have working recovery and installed on nand on all my boxes. but i dont do the "installtonand" command either.
woodg8 I do not believe the s905x supports more than 2gb of ram so either it is a s912 or it only has 2 gb. Either way, you would be much safer testing the original build from kszaq on sd card before doing anything.
Urgodfather It's this one here from geekbuying with 3gb ram http://www.geekbuying.com/item/Z69-A...OX-383201.html
woodg8 Personally I do not trust the specs on that. http://www.inexbox.com/s905-s905x-s912-specification/
I would ask kszaq on his main thread here : https://forum.libreelec.tv/thread/21...or-s905-s905x/
Jeffreyveh It appears that you have the wrong device tree. If you are familiar with command line, you can ftp the right device tree over and dd the device tree into the right location. Read some of the last few pages, as they have some good information for you.
My device is a COOWELL V5 tv stick 1 8 gb S905X quad-core CPU and Mali-450 GPU samsung wifi no Bluetooth
I can run LibreELEC from SD no problem.
But when I try to install it to the internal emmc the device hangs on boot.
I think the problem is the device tree but I have failed to find A working one.
Is there anybody who can point me to a working device tree?
I would like to install it to emmc memory
Greetings Herman
OK guys, I will be maintaining this project moving forward. I have not decided if I will make a new thread or not. This has been cleared with pinguy . I was waiting for him to make this announcement but I guess he has been too busy. Moving forward, I will be glad to help, provide updates, etc. I have not decided if I will be posting my images with the decryption key or not but in the mean time you can always PM me and I will send you the key to the image i have posted. I also have original backups if needed.
Ok Guys, Here is a copy of LibreElec 8.2. I have not had a chance to test it yet. It is for 2GB S905X only. Test if you want, I will when I can. Make sure you have a USB to USB cable to recover if it doesn't work and if you need original firmware you can message me. I only have NEXBOX a95x firmwares.
hi Urgodfather sorry for noobs question, but I'm running kzsaq's LE 8.2 / 8.1.9 build from SD card on my Mini M8S II (S905x) 2GB box - can I install your image above on to SD card and run that without effecting my android etc? thank you.
OK guys (and gals) I've started a new thread.Head on over to http://freaktab.com/forum/tv-player-...-for-s905x-new if you need help or updates.
There are currently 1781 users online. 0 members and 1781 guests.
