LibreELEC 7.0 For S905/X (old)
Ok guys, I need help. I have flashed LE on many boxes. Used this build on NEXBOX A95X 2/8 model no issue. On 2/16, I borked. I'm sure I goofed this up b/c I tried to restore a backup that I made off of the 2/8. Anyways now I'm stuck. I have gone through many different firmwares listed for this box (most start with cny or something like that) and cannot find a match to this box. Also, I cannot get twrp to boot anymore. I did make a backup from the same model if that will help.
I attempted to make one based off of the TWRP backup and the META-INF from this this. No bueno. Everything error's out. I do get into a stock recovery and could probably adb it. I keep getting an error about the /misc volume. Just for giggles, I tried to flash the lLE build. No difference. Sure would be nice to establish a recovery method for this box so I can brick it again. So close i can smell it. OR is it the ganja?
Please try an other memorycard. I've got the same problem. In my case i tried an other card and it works.
I used the AML Formatter tool.
Please try this firmware:
https://mega.nz/#!RJ9XARqT!aPh1Qp11U...9xGuc0V8dlf9OU
for SD CARD Update you need to extract all files on it.Last edited by statotec; 03 February 2017, 19:14.
thanks for the FW. did not work. attempted blank card with these files. nothing. tried to use my working boot sd card and flashing the zip. nothing. my working card has the aml_sdc_burn.ini, uboot.bin.sd.bin, and aml_upgrade_package.img. I will say, the zip did get further than any of my other attempts. but it did shoot out an error. ~~~> this package is for "p212" devices; this is a "nexbox_a95x2"
Urgodfather Have you tried the firmware from this post?
Please install the firmware with this method:
Insert the prepared SD Card into the box
Put a thoothpick in the AV Jack (you feel the "click") and put the power plug in
Holt the toothpick and wait until the update starts.
Originally posted by ClemFandango View Postare there any builds for the S905x's that contain Kodi 17 yet, or am i being too impatient ?
There are currently 3944 users online. 0 members and 3944 guests.
