Does anyone have the remote file for the x96 and MeCool H8 both 1gb/8gb
LibreELEC 7.0 For S905/X (old)
#this file is configuration for each factory remote device
# work_mode 0 :software mode 1 :hardware mode
# repeat_enable 0 :disable repeat 1 :enable repeat
# factory_code each device has it's unique factory code.
# pattern:custom_code(16bit)+index_code(16bit)
# examble: 0xff000001 = 0xff00(custom cod) 0001 (index)
# release_delay unit:ms.release will report from kernel to user layer after this period of time
# from press or repeat triggered.
# debug_enable 0 :debug disable 1 :debug disable
# SW MODE:
# bit_count how many bits in each frame
# tw_leader_act time window for leader active
# tw_bit0 time window for bit0 time.
# tw_bit1 time window for bit1 time
# tw_repeat_leader time window for repeat leader
# REG
# reg_base_gen set value for PREG_IR_DEC_BASE_GEN
# reg_control set value for PREG_IR_DEC_CONTROL
# reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE
# reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE
# reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE
# reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME
#amlogic NEC remote
factory_code = 0xfe010000
work_mode = 0
repeat_enable = 1
repeat_delay = 40
repeat_peroid = 39
release_delay = 121
debug_enable = 1
fn_key_scancode = 0x00
left_key_scancode = 0x51
right_key_scancode = 0x50
up_key_scancode = 0x16
down_key_scancode = 0x1a
ok_key_scancode = 0x13
mouse_begin
0 0x51 //mouse key left
1 0x50 //mouse key right
2 0x16 //mouse key up
3 0x1a //mouse key down
mouse_end
key_begin
0x11 102 #HOME
0x19 158 #EXIT
0x4c 125 #MENU
0x40 116 #ON/OFF
0x18 115 #VOL+
0x10 114 #VOL-
0x16 103 #UP
0x51 105 #LEFT
0x13 97 #DPAD_CENTER
0x50 106 #RIGHT
0x1a 108 #DOWN
0x41 113 #MUTE
0x5a 119 #PLAY_PAUSE
0x52 124 #MEDIA_PAUSE
0x0a 257 #MUSIC
# 0x49 261 #PICTURE PLAYER
0x4d 263 #SHORTCUT_VIDEOPLAYER
# 0x48 262 #SHORTCUT_FILEBROWSER
0x03 217 #SEARCH
0x0e 70 #267->WEBSITE #70-->EXPLORE
0x43 255 #SETTINGS
0x54 120 #FAST_FORWARD
0x55 121 #REWIND
0x59 122 #PREV
0x58 123 #NEXT
0x4e 2 #1
0x0d 3 #2
0x0c 4 #3
0x4a 5 #4
0x09 6 #5
0x08 7 #6
0x46 8 #7
0x05 9 #8
0x04 10 #9
0x01 11 #0
0x42 14 #DEL
# 0x52 128 #MEDIA_STOP
# 0x45 264 #ONEKEY_ZOOM
0x06 265 #SHORTCUT_SUBTITLE
0x44 266 #KODI
0x0f 233 #MAIN_MENU
# 0x12 269 # F9
0x47 112 #@ AT
0x0a 111 #MUSIC
0x4d 101 # (F3)VIDEO
0x49 66 #(F1)PHOTO
0x48 77 #(F2)FILE
0x12 88 #(F9)CLEAN
0xf2 140 #F10 oritation
0x4b 140 #F10 oritation
0x45 99 #(F6)ZOOM
key_end
Hello all.
I just bought a Tx3 Pro android box with 1gb ram and tried to install libreelec.
First I made a backup to the sd card from the recovery. then Installed the 7.0.3 version from the first post. On boot it gave me some error about checking filesystem. I flashed again It booted but gave other error:
Error in mount_storage: mount_common: could not mount /dev/data
Flashed then several times this version and the older 7.0.2 but no progress, same error again.
Then I wanted to restore the backup I made, it restored the backup, rebooted, but it boots to libreelec again and gives same error!
Then I don't know what to I read somewhere to do the comand fsck, but keyboard was not working.
Flashed again version 7.0.2 and somehow it booted correctly to openelec.
Weird right?
Was just me that had this problems?
EDIT:
All working fine now, here is what I did in case anyone needs:
The remote, I used the file from minim8sii, works fine.
Installed the kodi build that is on first post, works fine but sometimes I had freezes/ hangs just browsing the menus, I think it was stuck 100% cpu use because ssh connection didnt break, but I was forced to cut power. After some couple of freezes it didn't freeze any more, don't know why...
Then I Updated to 7.0.3 folowing instruction on libreelec forum. Put LibreELEC-S905.arm-7.0.3.012j.img.gz and gxl_p212_1g_nand.dtb on the update folder, rebooted and worked fine.
Then installed acestream and emulnation following a post on this forum, worked fine.
I wanted to create a samba share for the roms folder but it didn't allow me to write file smb.conf on /etc. Then I read that you need to edit the samba.conf.sample to your needs and then save it without the .sample and reboot. worked fine.
Grab it. I repacked newest Libreelec 17.1 build. All greetings ofc to kszaq and pinguy.
https://www.dropbox.com/s/wxgjecgm8s....0.1b.zip?dl=0
If you upgrade from 7.0.3 [16.1] it propably stuck on logo. After clean install it working well.
If it stuck you can flash back 7.0.3 version it will gonna work with your settings.
Tested on my Nexbox a95x 2/8.
Originally posted by manikcs View PostTested on my Nexbox a95x 2/8.
I have stock firmware with Android on it. I assume after installing TWRP and then this, everything will work including the wifi (because I read somewhere this: But the Pinguy build was using the wrong dtb.img for my box so I had no ethernet or wifi and the remote was not working...). But since you tested it with a Nexbox A95X it should work, right?
Originally posted by tonyrulez View Post
I have a Nexbox A95X 2/16 version. Will it work on that too?
BTW. New 8.0.1c is here:
Two new repacks:
TWRP-LibreELEC-S905X-2GB-7.0.3.012k [Kodi 16.1 Jarvis] - a lot of fixes from 8.0 branch merged to Jarvis
TWRP-LibreELEC-S905X-2GB-8.0-8.0.1j [Kodi 17.2-RC2 Krypton] - newest and greatest
Greetings only to @krzaq THE GOD.
Hi
This is my first post on this forum so please excuse my lack of knowledge ignorance.
I previously had a Androd Box that was pre loaded with everything but that got boring, so I thought I would by one and see if I could load LibreELEC onto it.
I recently got one of these http://www.****.com.au/itm/XGODY-NEW...-/282094247340 as a recommendation from another website (maybe not a good idea).
I have read all of the above posts but cannot get TWRP working from an HDSC 16gb card. Steps were followed exactly as described at the top of the post. Formatted card with RUFUS, copied the recovery.img to the card. Rebooted using the toothpick method and it takes me to a recovery screen where I continued to hold the toothpick in for about a minute. TWRP did not load. Tried several times all with the same result.
I then went to another forum where they mentioned that some of these boxes would not boot into TWRP due to the reset button in the A/V not working properly. I followed their instructions http://www.tvboxforum.com/printthread.php?tid=826 by copying an Update.zip file onto the card and rebooting. The post also made a mention of going into the update App on the box and manually locating the zip. to perform the install. I couldn't find this app on my Box. The Box automatically tried to open the Update.zip file but gave an error saying it wasn't a valid update file.
So now I'm thoroughly confused and would appreciate some help with this
There are currently 3934 users online. 0 members and 3934 guests.
