Scooters V88 pro Port...
Originally posted by zodiac9797 View PostThank you all for a great work!
I decided to try Magendanz Android TV ROM with this box, and it's working great. Only a couple of small issues, but this box is now alive
You can check this ROM here:
and my post here:
http://freaktab.com/forum/tv-player-...676#post674676
Hello.Send me please file V88 PRO remote.conf this firmware https://www.dropbox.com/s/7vm03y1w9n...88RC1.img?dl=0 Thank you
Hi all, I also got SCISHION V88 PRO and it took some time for me to understand why is this piece of crap so slow. The stock firmware has clocked the CPU at max 1000Mhz and set CPU to use only single core. Then I found another user with the same complaints - https://forum.xda-developers.com/sho...60&postcount=4, so its not only me.
Couldn't flash Magendanz's - Amlogic flash tool always gives errror on 4%
So now I flashed this firmware (v88repack.img) and it works much better. I have configured CPU for maximum performance using Kernel Auditor app. Thanks a lot!
The only minor issues are (already reported by other users):
* LED indicator is now swapped - red when ON, and blue when in STAND BY
* if powered off - could not be powered back on using remote
* KODI from Play Store does not work - crashes ass soon as I play an H246 MP4 file
Also I have a question. There is a notification about an OTA update available. Is it safe to update? Who provides those updates?
I have uploaded the Rom v88repack.img here, I hope you do wellLast edited by clydde; 24 March 2018, 23:10.
There are currently 3448 users online. 0 members and 3448 guests.
