Scooters V88 pro Port...
Originally posted by tomasiek View PostHello, I have uploaded today is soft and everything is ok. I have noticed that sometimes reboots and I had no option HDMI CEC.
Hello,
I am having problems flashing this ROM. I made a USB A to A cable and connected it to my PC.
I loaded the rom in usb burn tool 2.0.7.2 and clicked start and then connected the cable to the single back port of the V88 pro.
LEDs is red and device manager recognizes it as libusb WorldCup Device.
But it doesnt show the device in the burn tool and doesnt start flashing.
I also tried shorting the pins but that did not work either. Maybe i shorted the wrong pins?
Thanks for your help
Hi everybody. I've tried to load and flash the rom with default update apk but I've got several errors: "E: failed to mount /udisk"; "E: failed to map file". Then I tried to select "Apply update from EXT" (zip file is in SD card) but nothing to do, I got other errors: "E: Cannot load volume /misc"; E: failed to unmount /data" and "E: failed to set up expected mounts for install". I really don't know how I can do. Can anybody help me ? Thanks.
You can not flash this img by flash tool. You need to load on pc burning tool and flash via that program. If you wait a bit a new rom is being tested. 😁 Flashing this rom requires some skills for unbricking. It doesnt seem you have those so id stick to kevins port or stock. Regards.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 6674 users online. 1 members and 6673 guests.
