I would also recommend buying some copper or aluminum heatsinks for it. http://www.****.com/itm/8pcs-13x12x5...item3f6084c484 I have placed 5 of these on my boxes and it has helped. 2 on the ram on top and 2 on the bottom and 1 on the ssd. Now if only I knew if there was a pin out for a fan header I would buy the raspberry pi fan kit and solder that on.
Scooters V88 pro Port...
Originally posted by Kuno View Post
You need to start the burn tool, load the rom, press start, connect the box, THEN short the pins. Done this many times with this box.
I was thinking about fan, but did not consider if it helped much. The smallest fan I found was 40×40×10 mm and I think there is enough place to put it in, but I'm not sure about air circualation in this smal box. Maybe...
Btw as far as I remember these fans has 5V, so you can solder direct to power input or solder/connect to usb.
Make sure you keep contact on the correct pins then insert usb with rom started. When tool hits 4 percent you can release. If its not showing your not hitting pins correctly. Try againMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostMake sure you keep contact on the correct pins then insert usb with rom started. When tool hits 4 percent you can release. If its not showing your not hitting pins correctly. Try again
- run burn tool, upload image, press start
- connect usb
- As shown in picture, shorten contacts 3 and 4
Right?
Burn tool does not see box, nand chip makes sound and that's. I held for 3 minutes, nothing changed.
And is there no other way to update rom?
Scooter, I am really liking this firmware. The light is still red, but honestly, it makes it easier to have it in the room at night as the red LED is no where near as bright as that blue haha. The remote works, Kodi, whatever you did is freaking awesome. Still some bleeding through of the menu when items are playing, but I think that has more to do with the heat issues that this box has than your awesome firmware. Will try to figure out how to cool it better. Maybe a big metal plate haha.
If I connect the box to tv hdmi and then connect usb to pc (not power cable), I see on tv screen only aml logo and if I shorten pins tv losts video signal and nothing happens.
So stucked with previous port. I cIcannot understand what's wrong
UPD. I think I give up for now - burn tool does not connect to the box, with shorten pins or not. It's a bit pitty that remote doesn't work on this older version.
So, could not give you feedback for new versio, sorry.Last edited by Xenchz; 01 November 2016, 12:03.
You have to be usb rear port connected to pc with burning tool running and select new firmware press start. Make sure drivers installed first. Then select start in burning tool short pins and holding pin short plug in usb then when tool at 4 percent let go short.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostYou have to be usb rear port connected to pc with burning tool running and select new firmware press start. Make sure drivers installed first. Then select start in burning tool short pins and holding pin short plug in usb then when tool at 4 percent let go short.
If i connect to tv hdmi and power with usb, can only see amd logo - no more.
If I disconnect usb and connect power cable, box boots up and I see older version of port.
I don't know: I am doing something wrong or box is different in some way
Curious has anyone looked at building a custom TWRP so we don't have to short the pins to upgrade/downgrade after we've initially flashed it?
All of TWRP 3.x source is public. You can compile it on your own. This guide isn't going to be a step-by-step, word-for-word type of guide. If you're not familiar with basic Linux commands and/or building in AOSP then you probably won't be...
Originally posted by dwizzle View PostCurious has anyone looked at building a custom TWRP so we don't have to short the pins to upgrade/downgrade after we've initially flashed it?
Post 19.
Originally posted by scooter2014 View PostDouble check you actually short right pins and drivers installed. It works
Ok, nevermind, thank you for your help, but something is wrong this this box
There are currently 6114 users online. 1 members and 6113 guests.
