Scooters V88 pro Port...
Hello Scooter2014. Tested your repacked rom. Works all quite good, after update playstore and so on. I also install a kernel modifier app, setting governor from hotplug to performance and clock from 1500mhz to 2000mhz.
I found an issue:
If i power off the box (don't suspend and resume) i can't power on the box. It stay on red led. Can you confirm?
regards
ok , thank you for your feedback. Anyway with suspend setting , whenyou turn off and then turn on the box start and then reboot..so it does a fresh start anyway.
By the way i feel that those boxes (i have two) have a terrible network speed , resulting in a bad streaming video quality / drop. Tested with Netflix and Youtube 1080p.
I remember that you said that Neo's rom have a good wifi quality/speed, wondering when he put it online again...
He getting box so soon... I find kernel panics and try another release. Just re packing it today. Wifi good on mine it system ui issue now i try to fix. We get there seem like this device have quirky nan...Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostOk Thanks to Kevin/NeoMod/Pharjister.
Working.
Playstore
Network
Bluetooth
Task bar - Not Working
Screen shot- Not Working
Root - Finless ezroot. https://www.dropbox.com/s/wiswhh769c...zroot.zip?dl=0
Animation ---Tattman
Bloat removed.
Changed wallpaper/launcher
Flash via usb burning tool and once open log into network via wifi or port. Sign into google and update what ever is set to update in your apk.
Once its updated re boot flash ezroot and then reboot and let firmware have time to refresh about 5 minutes. Re boot you should be good to go. Install kodi of your choice and programs. I tested usb and sd card sd card works as system or portable no issues.
Post any issues ill try and look into them when i have time.
Normal disclaimer.... Your risk your money
Re packed link below oct16/2016
Enjoy.
Ill upload updated port later tonight.
Lots of issues with this box from dig eatting it to picking it back out of the trash and trying again and again. As well as filling up an entire drive of software ports. But looks like we have a winner 😂Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Just repacking now.... You can test please.
First Post updated Enjoy..... Read new comments.....Last edited by scooter2014; 29 October 2016, 04:04.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 6682 users online. 1 members and 6681 guests.
