Originally posted by Woogetybop View Post
So a question to you. What method do you use to boot into Libreelec? That's what I'm going to try next.
thank You,
Woogetybop
The only thing left to fix is the power on from the remote but would require re-installing original firmware and I can't be bothered at the moment.
Originally posted by Woogetybop View PostTwo things that come to mind is location of the remote.conf file, and more overlooked is setting the remote.conf file properties to 644. This is easily done though the file commander app's file properties settings.
Originally posted by johnnewbie View Post
I installed Terminal Shortcut from the Play Store, created a shortcut with the command "reboot update" check the run with root privileges checkbox. So much easier than fiddling about with the toothpick in the AV port.
I've read enough to know that the power on function is built into the boot code. So I figured now that it's running on modified Mini m8s II firmware I was going to get me a Mini M8S II remote control and put that remote.conf back in the system. Then everything will work correctly. I have the TV and my sound system CEC turned on. Currently I have to turn the tv on and go to settings, HDMI, then tell it to turn the tv Box on. Too many steps. I tested by removing power and back on again on the TV Box. So it acted as the start and It powered everything on together. So with the remote on button issue fixed I'll be golden.
Originally posted by Xannytech
You're totally OFF TOPIC, anyway it's not a good idea to buld a S912 Kernel with S905X sources.
If not a good idea where can i find proper s912 source for Android?
You are not really helpful but the others wasn't so enemy.
If you don't want to reply here, please reply under the proper thread I posted here or in PM. That would be the correct.Last edited by pszab; 21 July 2017, 15:17.
Originally posted by pszab View Post
I can accept that you're right but why. It has the q201 device.
Where can i find proper s912 source for Android?
Open a thread and we'll help you if we can.
Kindly
Xanny
Holy cow Xannytech you've been one busy coder. Hope to try out the new firmware soon, just need to find a new adapter for my Yundoo as it burned itself out so I am currently powering it through USB haha. I really hope your tip jar is getting full with all these new people coming here. Thank you for your hard work and dedication to this project. In the next week or so I will be trying out your new firmware and will let you know what I think
Originally posted by ddogishere View PostHi you OK? Was it you that produced step by step guide of how to change the bootloader so you can use the full function of the remote (nexbox) on this brilliant Xanny Rom? Many thanks."HANDS ARE NATURES FORKS" -Rigby
Hi. I have a Mini M8S II that i have running xannytech rom, and i can update it anytime.
Now i have bought another one, but i cant update it. Neither using the sd card method (says it cant mount the sd card or something like that, in the recovery), nor the burning tool.
Has anyone managed to install the rom, on a new box lately? If so, any tips?
best regards,
azizlaite
EDIT: Several other users are reporting bricked boxes after trying to update the rom (http://freaktab.com/forum/tv-player-...-with-nand-pin). Seems there's something different with the new batch of boxes. So caution is advised (and help, very much aprecciated).Last edited by azizlaite; 31 July 2017, 23:29.
There are currently 3037 users online. 2 members and 3035 guests.
