Xannytech needs your help. I received my fourth box2 / 16 .the 16-8 with a funny Rom and also a kodi that I do not know. I wanted to change her rom. It was impossible always the same answer
(0x00101004) Erase bootloader / LOwper / Identify / Error result
[0x10105002] Romcode / Initialize DDR / Read initialize status / USB Control setup error. Can not install the driver wordcup device
My usb + cable are good try on my other 3 MINIM8SII no problems my pc easily recognize my minim8 sii
I started to prepare my floppy disk to go the way Burn Card Maker
I notice that my device does not turn on. The unit stops lighting after 1 day of use. I think I was sold a clone, buy at .gearbest.com I asked for help at gearbest.com. No response from them thank you for your help No light. Nor blue. Nor red
hi, i have problem and i can not flash the rom. when i use the amlogic burn tool it says every time
[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
I tried this rom and other but the problem stays the same.
I tried also and the sd card but nothing happens. Can anyone help me? No my tv box wont work at all.
Originally posted by zafeira View Posthi, i have problem and i can not flash the rom. when i use the amlogic burn tool it says every time
I tried also and the sd card but nothing happens. Can anyone help me? No my tv box wont work at all.It's a little bit difficult give help without informations
Originally posted by totor54 View PostXannytech needs your help. I received my fourth box2 / 16 .the 16-8 with a funny Rom and also a kodi that I do not know. I wanted to change her rom. It was impossible always the same answer
My mistake my tv box is mini m8s II 2GB RAM.
Anyway if you own the right Mini M8SII or a P212 device the procedure to force a little the flash it's pretty simple (i'm not responsible if your device is not compatible):
- open the Amlogic Burnig Tool 2.08;
- select english language (it's better);
- import the rom you want to flash;
- click start on the program;
- insert a usb plug in the PC port;
- take a toothpick;
- insert toothpick in the reset button of the Mini M8S II (the device has to be powered off and disconnected) and keep reset button pressed (normally i do this with my left hand);
- Plug the other end of the cable in the usb port near HDMI;
- wait until windows recognize the box with toothpick pressing reset;
- the flash will start.
Originally posted by Xannytech View Post
Some very new devices are out with a new motherboard, the original Mini M8SII has a reference P212 Motherboard. Flashing new devices with new motherboard could bring to unfuncional devices. But i cannot be sure which device do you own. You should open it.
- take a toothpick;
Anyway, i will try your info to see what happens. Thanks againYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
thank you very much for your info. I will try again. But as you can see from the pics maybe i was mistaken and it's not mini m8s ii? i thought that it was amlogic s905x instead i can see that it says s905??? So please can anyone confirm that i am right or wrong? So maybe the whole point was wrong firmware? Or i am
It's a Original Mini M8SII with reference P212 Board so it's safe to flash.
I am out of solutions what else could i do? The box is not working at all. It just pops up the blue light and i cant see anything. I know that i erased the bootloader and now is useless unless i flash some kind of firmware. I will try again anyway thanks a lot Xannytech for your time.
ta reponse est la
Bricked "Mini M8S II" (Clone?) - Looking for help with NAND-pin
http://freaktab.com/forum/tv-player-...-with-nand-pin
poste 60 merci Lukovsky pour la rom
There are currently 1730 users online. 0 members and 1730 guests.
