@ZeRoZeRoRaZ you do not want to install this on a MiBox as a MiBox is an OFFICIAL Box which has proper support for every single app from Google and installing this firmware will break every single thing and you're box will be broken. This is for cheap Chinese boxes. For your MiBox your best bet is to go to Xiaomi support threads, not here.
XTMOD EX 3.0 standard version
RELEASE NOTE/MODIFICATION FROM PREVIOUS VERSION:
- Updated Google Play Services;
- Updated Google Play (market);
- New app list: - Amazon Prime;
- Adaway
- Aptoide (very useful sometimes, but be careful);
- Google Chrome;
- Google Calendar;
- Google Play Music;
- Google Play Videos;
- Google Voice Search;
- Terminal Emulator;
- MX Player;
- Netflix;
- SPMC;
- Total Commander;
- XposedInstaller + Youtube Adaway + BootManager Modules;
- Youtube.
All the apps are at the last version available during compilation.
- Fixed a stupid bug in kernel, it was just a typo;
- Some automatic script revised or removed;
- Pre-Setted some apps (Mxplayer, Xposed Total Commander and SQHome Launcher);
- New Bootlogo, New Bootvideo, New Bootanimation, New Wallpaper;
- Many thing very important that i forgot to write down(because pratically i ported my PERSONAL rom).
I don't know if i can do more on this kind of firmware, next will be the official Android Tv Rom (actually i posted just three betas).
Enjoy
Xanny
XTMOD 3.0 for TvBoxes with motherboard P212 with wifi chipset : AP62X2, AP4354, AP4356, AP6212, AP6212A, AP6255, AP6335, AP43458, AP6330, 8723xx (Bluetooth not working), 8188XX, 8189XX, 8192XX, 8812XX
If you have a 9377 wifi chip device flash the image, then after the first boot is complete, go to recovery and install this file:
- wifi 9377 twrp file
- XTMOD 3.0 for D4X16 Motherboard
Some new Mini M8SII comes out with a new motherboard, is green, there is a label D4X16, you can see that label just opening the device, for the one and just for the one with such motherboard, do not flash it on normal Mini M8SII.
I will KINDLY NOT REPLY to any request such which wifi i own? Which Motherboard has my device? It's YOUR device not mine
Amlogic Usb Burning tool 2.1.2:
https://mega.nz/#!i8pxACKC!EIP9DucLY...7-j3r-NKDBEjFs
TF/SD Burn Card Maker 2.0.3:
https://mega.nz/#!SowFiSID!mEk8gp5qN...xYS5xviDNSUdE8
P.S.
I will update first page a.s.a.p. not immediately... sorry.
Hello Xanny,
thank you very much for your new rom. installed on Tanix TX5 Pro with wifi 6255 today. changed the remote.inf according to your instructions in first page. everything appears to run well. your configuration of squarehome 2 is just right for me. waiting for your Android TV rom...
have a nice day.
Hello Xanny,
I try to upload your fw to m96x (http://www.dx.com/p/m96x-mini-androi...4#.WdznsFu0OUk) but the USB burning tool keeps telling me:
[0x10105004]Romcode/Initialize DDR/Read initialize status/Error result
I made a photo of the board, maybe it helps
My reason to use this fw is the hdmi color issue with old Philips TV.
Would you please help me,
Originally posted by cubasekid View PostWorking great on U2c Z Pro box 2/8gb (including wifi)
Thanks very much for this great FW....
OK i spoke to soon!
all was working great until i added SD card as extra internal storage. selecting to use as internal storage and migrating data completed without error however, i found no apps moved to the card and if i try to manually move app by app i get 'no available space' error
i cant see the SD card in es file explorer, it only shows the internal storage. if i look in Kodi or SPMC file manager i can only find internal also, all i can see is 'sd card' and this shows the internal storage. There is no way to find the external card. if i look in android settings it shows internal and sd card but i only have option to 'explore' internal. the option does not show if i select the SD card.
I found however if I install new app from play store i am able to move to the SD so reinstalled SPMC then moved it.
all good i thought until i restored SPMC back up, it filled internal storage until there was no space left and SPMC would no longer open :-(
i tried with two different SD cards that work fine in this way if i format them as internal on other devices.
i thought maybe something had gone awry flashing in the first instance so flashed again and configured from scratch but got the same result, then tried again with the SD inserted through the flashing process in the vain hope it may get wiped / set up it but was just left ready for me to pick as additional or internal storage, and gave same results again...Last edited by cubasekid; 13 October 2017, 08:21.
[QUOTE=cubasekid;n677532]
***UPDATE***
OK i spoke to soon!
i thought maybe something had gone awry flashing in the first instance so flashed again and configured from scratch but got the same result, then tried again with the SD inserted through the flashing process in the vain hope it may get wiped / set up it but was just left ready for me to pick as additional or internal storage, and gave same results again...[/QUOTE]
That's Android 6.01 not meInternal memory it's for the system an extension of the internal memory, android 4 or 5 worked differently.
Hi Xanny,
What do you think, is there any chance to recover from this:
GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EM MC:0;READ:0;0.0;CHK:0;
TE: 47693
BL2 Built : 13:48:56, Sep 23 2016.
gxl g7459bd4 - jianxin.pan@droid06
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 2
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR3 chl: Rank0+1 @ 720MHz - FAIL
DDR3 chl: Rank0 @ 720MHz - FAIL
DDR3 chl: Rank0 16bit @ 720MHz - PASS
Rank0: 1024MB-2T-11
DataBus test pass!
ADDR-W[0x20000000]:0xaaaaaaaa,R:0xc3512a13
ADDR3-W[0x00000004]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00000008]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00000010]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00000020]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00000040]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00000080]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00000100]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00000200]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00000400]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00000800]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00001000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00002000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00004000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00008000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00010000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00020000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00040000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00080000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00100000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00200000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00400000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x00800000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x01000000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x02000000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x04000000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x08000000]:0x55555555,R:0x3caed5ec
ADDR3-W[0x10000000]:0x55555555,R:0x3caed5ec
AddrBus test failed!!!
I can reach the box by an FTDI232 module but DDR configuration seems to be wrong. Do I have any hope to use the USB Burning Tool?
TE: 47693
set vcck to 1120 mv
Board ID = 2
CPU clk: 1200MHz
DQS-corr enabled
Rank0: 1024MB-2T-11
DataBus test pass!
I can reach the box by an FTDI232 module but DDR configuration seems to be wrong. Do I have any hope to use the USB Burning Tool?please...
1rst... which device is?
2nd for sure you need:
- Amlogic Usb Burning tool
- Usb male to male cable
- original fw for your device in .img format
Then you should try to flash it with your original fw.
3rd I have no idea of what you did, so how can help you?
4rth i'm not really a chinese box help centeri know you need help but.. you know... forum rules netiquette etc. etc.
There are currently 2415 users online. 0 members and 2415 guests.
