How to fix it?
Originally posted by Scrimerr View PostI have a little problem. In this great rom, KODI it always starts the first time after rebooting the tv-box ( 6GB free space on my NexBox A95X 2/16 tv-box)
How to fix it?
xannytech I need help
This is off topic but kindly help me. I have nexbox S905X but after installing nexbox default 7.1 andriod firmware after upgrading there is no option available in youtube app to play videos of 1080p just 720p option available. I installed youtube andriod tv app or simple Youtube app but only 720p option available to stream videos. I successfully played 1080p videos in previous xanny tech firmware. Kindly help?
Originally posted by Xannytech View Post
? If it's just spmc that shows "preparing for first start "it's not a problem, it's a cleaning script that cleaned all the junk. Spmc works as it should also if write that after a reboot, you'll lose nothing.
Originally posted by hojnikb View Post
Anyone ?
Not an easy task, you need to decompile the whole rom, decompress the bootlogo, use an bmp rgb 24bit, recompile the rom, and you'll end losing twrp recovery...and my bootvideo still remain there.
Anyway if you can live with my bootlogo, you can easily change bootvideo it's in system/etc/ .
First off, thanks for your continued work and support for your ROM XT.
I had a few issues that I found answers to, but I still have one kind of nitpicky issue though. When my box reboots or powers on again, the navbar is not visible by default... I have to drag it back up again, even if it was there before reboot. Is there anyway to have it stay there on startup?Last edited by rahzel; 30 November 2017, 08:01.
Originally posted by rahzel View PostFirst off, thanks for your continued work and support for your ROM XT.
Originally posted by Methanoid View PostIs there any way to make this Rom pass Google's SafetyNet test (which checks for Root, and some Integrity tests) - I know Magisk works for phones but no idea how to put that on this box? Definitely do NOT want any Google security updates dated AFTER Feb 2017 too ;-)
Anyway also with Magisk installed you can't pass Safety Net for various reasons:
1. bootloader is unlocked;
2. Selinux is disabled, not permissive, but disabled.
So it's totally unuseful, if it's just for netflix you can download the latest updated app from APKMIRROR.
And Chainfire developed a similar su-hide app for his root.
I replied many times to this question. Magisk does not recognize boot partition of our devices, i don't know if the reason is TWRP or Magisk, but for sure it's not my rom
thanks for the full answers.
I was going to have a play with Magendanz's rom but even with the reset pressed there seems to be no recovery on my box? it just boots into your Rom every time. I know I AM pressing the reset as it WILL tell the machine to shutdown if pressed when the rom has booted. Since I cannot get into recovery I cannot use the SD card update and I dont think I have a USB M-M cable. IS there anything I can do? Will M-M cable definitely work?
There are currently 1907 users online. 1 members and 1906 guests.
