Originally posted by Xannytech View Post
So you solved in that way? The odd part is that he wrote he tried my twrp zip without success, that is the same version of twrp you're linking.
ok let me know so i can post the fix in First pagethanks again.
1. Download the P212 twrp from " https://1drv.ms/u/s!AoqocX31ecnXgZwNCL9pqWEsLDw_hg " and rename to recovery.img and copy to micro sd card
2. Flash the recompiled Rom for Nexbox as posted in first page ssarava9 using amlogic usb tool
3. after first boot, place the micro sd card into the box and go to Terminal emulator app (because toothpick is not working after flashing the rom for some reason) and type "Reboot update" and enter
4. Now the box will boot into TWRP from SD card and install the marketfix zip file from Xanny which is also in first page
5. Now reboot to system, voila you should not see the google playstore stopped working error
Let me know for any questions.
Originally posted by Scrimerr View Post
Please provide a tutorial how to do it or if you can link to the tutorial
Do I copy ten file from you on SD and install it via TWRP "Install"?
Yes i tried and worked successfully, here is what i did for my Nexbox 2/16 S905x, it may also work on 1/8 g box:
Originally posted by rajawaqas View Post
It’s working. But I m using libreelec through sd card when I boot from internal( from libreelec to nexbox’s xanny andriod) again goto twrp loop
Originally posted by rajawaqas View PostI tried its successful when I remove p212 recovery image based sd card and plug in libreelec based sd card. then again goto twrp loop when I boot from internal
It worked perfectly fine, i was able to reboot from libreelec to internal to android rom with SD card in, i would suggest to retry removing the twrp sd card and inserting libreelec card
Originally posted by rajawaqas View PostI tried alternate method but in vain.. I execute command reboot update and reboot through libreelec card and remove libreelc sd card and insert twrp sd card but still stuck in twrp root
I'm confused as you mentioned earlier that you cant reboot to internal from Libreelec when SD card is inserted, then why did you remove the libreelec card
This is what i have:
1. Libreelec card inserted to box
2. typed "reboot update" in terminal emulator
3. now box will load into libreelec (libreelec sd card still inserted in the box)
4. in Libreelec , choose reboot to internal, it will reboot to android rom
Let me know if im not getting you
you should not insert twrp sd, because it will take you to twrp recovery
There are currently 3139 users online. 1 members and 3138 guests.
