trying to make backup with TWRP recovery mode after deleting many apps like kodi music video netflix and adding my app of 60mb while backing up now the size shown i s arround 2011MB. is it normal or its huge or required some xtra work. To install on other boxes should i zip the backup folder and install through usb burning tools . If you can give some tips.
Regards
Originally posted by maani_ch View Posttrying to make backup with TWRP recovery mode after deleting many apps like kodi music video netflix and adding my app of 60mb while backing up now the size shown i s arround 2011MB. is it normal or its huge or required some xtra work. To install on other boxes should i zip the backup folder and install through usb burning tools . If you can give some tips.
Regards
Originally posted by Xannytech View PostSo for the users that own a Mini M8SII with D4X16 Motherboard i created a FW that should work on their devices.
It's a updated version of my Custom with Bootloader and other part of the FW that has been posted here for D4X16 motherboard devices.:
XTMOD 2.9 for D4X16
I obviously did not test this ROM 'cause i do not own such device, but if you own one and need a custom for it try it and report here in my thread.
Xanny
Originally posted by gale View Post
Wifi speed is the same(slow) with Xannytech XTMOD 2.9 for D4X16 ROM.
then please remember before talking to me, bring me RESPECT.
I gave to the user of your faulty revision a ultra-refined and fast custom ROM for FREE (the first and the only for a while)!!!!
If the WIFI is slow it's a hardware issue (poor antenna), i'm not the producer!
Myself installed a external antenna, problem solved.
You're just pityful trying to induce me to develop a better wifi driver, but i can't because i'm not the producer, if you're convinced that it's a software issue write to the one that got your money and bring respect to me.
CLEAR?Last edited by Xannytech; 31 August 2017, 00:18.
You wrote that two times, here and in the thread about how to unbrick, so it's crossposting and seems just you complaining... don't seem to you odd?
CLEAR?
Gale the post you linked is a fix for another box nothing to do with your post of a external fix. Your post links a wifi fix for software. Not a mod. If your not happy with wifi move along.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 2474 users online. 0 members and 2474 guests.
