    Originally posted by reverendo View Post
    Yes that is right. 16.1 from play store. It sometimes starts with a green screen. The Kofi start screen sometimes appears after a few seconds of green or appears if I fiddle with the TV aspect ratios. But sometimes not and I have to restart. Kodi 17 beta seems to start consistently without issues.
    i will post some log excerpts later.
    thanks all
    u use that version?
    UPDATED VERSION BASED ON V109 LINKS!!
    Flash with Amlogic_USB_burning_tool_2.0.8:
    XTMOD_EX_P .IMG (it's in .7z format just for space reason)
      thanks all
      the greenish thing is caused by amcodec...
      Kodi 17 beta 7 is out
        Thanks Xannytech - yes I just find that new Kodi interface a little difficult to get along with. To me everything seems to be a few more clicks away than it was in 16.x !
        thanks Bajann - yes that is the image I am using.
          Hi all! Xannytech, thank you for your work !
          I own a Docooler R39X (s905x 1g 8g ). It is just a Scishion V88 Pro .
          Same box, same pcb and the model number is (was) V88 pro.
          The original rom was very slow (in fact the box was not usable) with very high temperatures.
          Then i read (4PDA) that the box is compatible with roms for NEXBOX A95X (S905X 1Gb/8Gb) and MINI M8S II (S905X 2Gb / 8Gb).
          So i flashed the latest rom for A95X (cyx_NEXBOX-A95X_S905X_8189etv_8g1g_kodi_addons_161104_SD_USB ) . Very fast
          but still hot and laggy connection with my airmouse-keyboards (MX3 and Measy GP811).
          Then i used your roms, first the MINIM8SII_XTMOD_P then the XTMOD_EX_P.
          With both the box is really fast , the recovery works just fine and the temperature is better.
          Minor problems : needs the original remote.conf, reversed led colors (red=on , blue=standby) , cannot wake up with power button
          (but wakes when i switch on the tv, so not really a problem)
          BUT with both there is a serius problem. If i leave the box on, but without action, for some time (1-2 hours), it freezes
          and the screen flashes in green-red-blue with grain, vertical lines and with a sound like a buzzer. This also happens some times
          during boot (once i had to unplug-replug the power 5 times ) .Also happened 1 time during an Antutu 3D test.
          But seems to be random and i cannot reproduce it, just wait to happen. I reflashed both roms 2-3 times (.img and .zip versions) nothing changed.
          I thought it has the temperature, i changed the heatsink with a bigger one from an old vga had a temperature drop but nothing else changed.
          Any ideas ?
ID:	618321Click image for larger version
ID:	618322Click image for larger version
            Here are some relevant log entries. This is Kodi 17 beta 7 with Velocity. It will not launch, instead gives an error advising me to check the logs. this is posted just for curiosity and in-case anyone can spot the issue. I don't think this error is anything to do with the image.
            Code:
            16:50:12.315 T:18446744073431419184   DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.velocity/)
            16:50:12.315 T:18446744073431419184   DEBUG:   ParentPath = [plugin://plugin.video.velocity/]
            16:50:12.339 T:18446744073111079216   DEBUG: CAddonDatabase::SetLastUsed[plugin.video.velocity] took 24 ms
            16:50:12.340 T:18446744073112123696   DEBUG: StartScript - calling plugin Velocity('plugin://plugin.video.velocity/','7','')
            16:50:12.350 T:18446744073058384176   DEBUG: Thread LanguageInvoker start, auto delete: false
            16:50:12.351 T:18446744073058384176    INFO: initializing python engine.
            16:50:12.351 T:18446744073058384176   DEBUG: CPythonInvoker(9, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity/default.py): start processing
            16:50:12.406 T:18446744073058384176   DEBUG: -->Python Interpreter Initialized<--
            16:50:12.407 T:18446744073058384176   DEBUG: CPythonInvoker(9, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity/default.py): the source file to load is "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity/default.py"
            16:50:12.408 T:18446744073058384176   DEBUG: CPythonInvoker(9, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity/default.py): setting the Python path to /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity:/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.urlresolver/lib:/:/data/app/org.xbmc.kodi-1/base.apk/assets/python2.7/lib/python27.zip:/data/app/org.xbmc.kodi-1/base.apk/assets/python2.7/lib/python2.7:/data/app/org.xbmc.kodi-1/base.apk/assets/python2.7/lib/python2.7/plat-linux2:/data/app/org.xbmc.kodi-1/base.apk/assets/python2.7/lib/python2.7/lib-tk:/data/app/org.xbmc.kodi-1/base.apk/assets/python2.7/lib/python2.7/lib-old:/data/app/org.xbmc.kodi-1/base.apk/assets/python2.7/lib/python2.7/lib-dynload
            16:50:12.408 T:18446744073058384176   DEBUG: CPythonInvoker(9, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity/default.py): entering source directory /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity
            16:50:12.409 T:18446744073058384176   DEBUG: CPythonInvoker(9, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity/default.py): instantiating addon using automatically obtained id of "plugin.video.velocity" dependent on version 2.1.0 of the xbmc.python api
            16:50:12.819 T:18446744073431419184   DEBUG: ------ Window Init (DialogBusy.xml) ------
            16:50:13.868 T:18446744073058384176  NOTICE: URLResolver: Initializing URLResolver version: 3.0.26
            16:50:13.874 T:18446744073058384176   DEBUG: URLResolver: Relevant Resolvers: [<class 'urlresolver.plugins.videowood.VideowoodResolver'>, <class 'urlresolver.plugins.youwatch.YouWatchResolver'>, <class 'urlresolver.plugins.vshare.VshareResolver'>, <class 'urlresolver.plugins.videocloud.VideocloudResolver'>, <class 'urlresolver.plugins.putload.PutLoadResolver'>, <class 'urlresolver.plugins.watchers.WatchersResolver'>, <class 'urlresolver.plugins.vivosx.VivosxResolver'>, <class 'urlresolver.plugins.streaminto.StreamintoResolver'>, <class 'urlresolver.plugins.videoweed.VideoweedResolver'>, <class 'urlresolver.plugins.vk.VKResolver'>, <class 'urlresolver.plugins.veeHD.VeeHDResolver'>, <class 'urlresolver.plugins.streamplay.StreamplayResolver'>, <class 'urlresolver.plugins.mp4stream.Mp4streamResolver'>, <class 'urlresolver.plugins.uptobox.UpToBoxResolver'>, <class 'urlresolver.plugins.thevideos.TheVideosResolver'>, <class 'urlresolver.plugins.watchvideo.WatchVideoResolver'>, <class 'urlresolver.plugins.fastplay.FastplayResolver'>, <class 'urlresolver.plugins.vidup_org.VidUpResolver'>, <class 'urlresolver.plugins.fileweed.FileWeedResolver'>, <class 'urlresolver.plugins.vimeo.VimeoResolver'>, <class 'urlresolver.plugins.videozoo.VideoZooResolver'>, <class 'urlresolver.plugins.streamcloud.StreamcloudResolver'>, <class 'urlresolver.plugins.clicknupload.ClickNUploadResolver'>, <class 'urlresolver.plugins.movshare.MovshareResolver'>, <class 'urlresolver.plugins.ecostream.EcostreamResolver'>, <class 'urlresolver.plugins.realdebrid.RealDebridResolver'>, <class 'urlresolver.plugins.playu.PlayUResolver'>, <class 'urlresolver.plugins.rpnet.RPnetResolver'>, <class 'urlresolver.plugins.estream.EstreamResolver'>, <class 'urlresolver.plugins.uploadz.UploadzResolver'>, <class 'urlresolver.plugins.cloudzilla.CloudZillaResolver'>, <class 'urlresolver.plugins.ok.OKResolver'>, <class 'urlresolver.plugins.vshareeu.VshareEuResolver'>, <class 'urlresolver.plugins.megamp4.MegaMP4Resolver'>, <class 'urlresolver.plugins.aliez.AliezResolver'>, <class 'urlresolver.plugins.speedplay.SpeedPlayResolver'>, <class 'urlresolver.plugins.xvidstage.XvidstageResolver'>, <class 'urlresolver.plugins.mp4upload.Mp4uploadResolver'>, <class 'urlresolver.plugins.blazefile.BlazefileResolver'>, <class 'urlresolver.plugins.cloudmailru.MailRuResolver'>, <class 'urlresolver.plugins.jetload.JetloadResolver'>, <class 'urlresolver.plugins.downace.DownaceResolver'>, <class 'urlresolver.plugins.simplydebrid.SimplyDebridResolver'>, <class 'urlresolver.plugins.allvid.AllVidResolver'>, <class 'urlresolver.plugins.facebook.FacebookResolver'>, <class 'urlresolver.plugins.tunepk.TunePkResolver'>, <class 'urlresolver.plugins.vodmine.VodmineResolver'>, <class 'urlresolver.plugins.weshare.WeShareResolver'>, <class 'urlresolver.plugins.watchonline.WatchonlineResolver'>, <class 'urlresolver.plugins.vidmad.VidMadResolver'>, <class 'urlresolver.plugins.mailru.MailRuResolver'>, <class 'urlresolver.plugins.idowatch.IDoWatchResolver'>, <class 'urlresolver.plugins.thevideo.TheVideoResolver'>, <class 'urlresolver.plugins.uploadaf.UploadAfResolver'>, <class 'urlresolver.plugins.indavideo.IndavideoResolver'>, <class 'urlresolver.plugins.tusfiles.TusfilesResolver'>, <class 'urlresolver.plugins.kingfiles.KingFilesResolver'>, <class 'urlresolver.plugins.nosvideo.NosvideoResolver'>, <class 'urlresolver.plugins.divxstage.DivxstageResolver'>, <class 'urlresolver.plugins.nowvideo.NowvideoResolver'>, <class 'urlresolver.plugins.vidlox.VidloxResolver'>, <class 'urlresolver.plugins.videa.VideaResolver'>, <class 'urlresolver.plugins.mp4engine.Mp4EngineResolver'>, <class 'urlresolver.plugins.hugefiles.HugefilesResolver'>, <class 'urlresolver.plugins.vidto.VidtoResolver'>, <class 'urlresolver.plugins.promptfile.PromptfileResolver'>, <class 'urlresolver.plugins.alldebrid.AllDebridResolver'>, <class 'urlresolver.plugins.openload.OpenLoadResolver'>, <class 'urlresolver.plugins.youtube.YoutubeResolver'>, <class 'urlresolver.plugins.grifthost.GrifthostResolver'>, <class 'urlresolver.plugins.play44_net.Play44Resolver'>, <class 'urlresolver.plugins.videoraj.VideoRajResolver'>, <class 'urlresolver.plugins.toltsd_fel.Toltsd_felResolver'>, <class 'urlresolver.plugins.movdivx.MovDivxResolver'>, <class 'urlresolver.plugins.movpod.MovpodResolver'>, <class 'urlresolver.plugins.anyfiles.AnyFilesResolver'>, <class 'urlresolver.plugins.zstream.ZstreamResolver'>, <class 'urlresolver.plugins.googlevideo.GoogleResolver'>, <class 'urlresolver.plugins.premiumize_me.PremiumizeMeResolver'>, <class 'urlresolver.plugins.vidcrazynet.VidCrazyResolver'>, <class 'urlresolver.plugins.vidme.VidMeResolver'>, <class 'urlresolver.plugins.ani-stream.AniStreamResolver'>, <class 'urlresolver.plugins.rutube.RuTubeResolver'>, <class 'urlresolver.plugins.rapidvideocom.RapidVideoResolver'>, <class 'urlresolver.plugins.dailymotion.DailymotionResolver'>, <class 'urlresolver.plugins.yourupload.YourUploadResolver'>, <class 'urlresolver.plugins.speedvideo.SpeedVideoResolver'>, <class 'urlresolver.plugins.playwire.PlayWireResolver'>, <class 'urlresolver.plugins.castamp.CastampResolver'>, <class 'urlresolver.plugins.rapidvideo.RapidVideoResolver'>, <class 'urlresolver.plugins.tudou.TudouResolver'>, <class 'urlresolver.plugins.vidbull.VidbullResolver'>, <class 'urlresolver.plugins.cloudy.CloudyResolver'>, <class 'urlresolver.plugins.zevera.ZeveraResolver'>, <class 'urlresolver.plugins.userscloud.UsersCloudResolver'>, <class 'urlresolver.plugins.usersfiles.UsersFilesResolver'>, <class 'urlresolver.plugins.veoh.VeohResolver'>, <class 'urlresolver.plugins.stagevu.StagevuResolver'>, <class 'urlresolver.plugins.videobee.VideoBeeResolver'>, <class 'urlresolver.plugins.playedto.PlayedtoResolver'>, <class 'urlresolver.plugins.streamenet.EstreamResolver'>, <class 'urlresolver.plugins.vidzi.VidziResolver'>, <class 'urlresolver.plugins.gorillavid.GorillavidResolver'>, <class 'urlresolver.plugins.uploadx.UploadXResolver'>, <class 'urlresolver.plugins.powerwatch.PowerwatchResolver'>, <class 'urlresolver.plugins.vidup_me.VidUpMeResolver'>, <class 'urlresolver.plugins.vodlocker.VodlockerResolver'>, <class 'urlresolver.plugins.exashare.ExashareResolver'>, <class 'urlresolver.plugins.playhd.PlayHDResolver'>, <class 'urlresolver.plugins.videohut.VideoHutResolver'>, <class 'urlresolver.plugins.purevid.PureVidResolver'>, <class 'urlresolver.plugins.novamov.NovamovResolver'>, <class 'urlresolver.plugins.flashx.FlashxResolver'>, <class 'urlresolver.plugins.mersalaayitten.MersalaResolver'>, <class 'urlresolver.plugins.trollvid.TrollVidResolver'>, <class 'urlresolver.plugins.filehoot.FilehootResolver'>, <class 'urlresolver.plugins.teramixer.TeramixerResolver'>, <class 'urlresolver.plugins.daclips.DaclipsResolver'>, <class 'urlresolver.plugins.myvidstream.myVidStream'>, <class 'urlresolver.plugins.filepup.FilePupResolver'>, <class 'urlresolver.plugins.twitch.TwitchResolver'>, <class 'urlresolver.plugins.videorev.VideoRevResolver'>, <class 'urlresolver.plugins.megadebrid.MegaDebridResolver'>, <class 'urlresolver.plugins.auengine.AuEngineResolver'>, <class 'urlresolver.plugins.letwatch.LetwatchResolver'>, <class 'urlresolver.plugins.uploadc.UploadcResolver'>, <class 'urlresolver.plugins.watchpass.WatchpassResolver'>, <class 'urlresolver.plugins.sharedsx.SharedsxResolver'>]
            16:50:13.904 T:18446744073058384176   DEBUG: URLResolver: No Settings Update Needed
            16:50:14.191 T:18446744073058384176   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                         - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                                        Error Type: <type 'exceptions.ImportError'>
                                                        Error Contents: No module named t0mm0.common.net
                                                        Traceback (most recent call last):
                                                          File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity/default.py", line 28, in <module>
                                                            from libs import kodi,trakt_auth,trakt
                                                          File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity/libs/trakt_auth.py", line 8, in <module>
                                                            from tm_libs import watched_cache
                                                          File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity/tm_libs/watched_cache.py", line 6, in <module>
                                                            from libs import log_utils,trakt
                                                          File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity/libs/trakt.py", line 11, in <module>
                                                            from tm_libs import cache_stat
                                                          File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.velocity/tm_libs/cache_stat.py", line 8, in <module>
                                                            from t0mm0.common.net import Net
                                                        ImportError: No module named t0mm0.common.net
                                                        -->End of Python script error report<--
            16:50:14.213 T:18446744073431419184   DEBUG: ------ Window Init (DialogNotification.xml) ------
            16:50:14.365 T:18446744073058384176    INFO: Python script stopped
            16:50:14.366 T:18446744073058384176   DEBUG: Thread LanguageInvoker 18446744073058384176 terminating
            16:50:14.381 T:18446744073431419184   ERROR: GetDirectory - Error getting plugin://plugin.video.velocity/
            16:50:14.383 T:18446744073431419184   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.velocity/) failed
            16:50:14.384 T:18446744073431419184   DEBUG: CGUIMediaWindow::GetDirectory ()
            16:50:14.384 T:18446744073431419184   DEBUG:   ParentPath = [plugin://plugin.video.velocity/]
            16:50:14.423 T:18446744073058384176   DEBUG: Thread BackgroundLoader start, auto delete: false
            16:50:14.442 T:18446744073058384176   DEBUG: Thread BackgroundLoader 18446744073058384176 terminating
              Any ideas ?
              i never seen something similar, but could be related to hdmi or memory, you know my custom is done for 2Gb devices... otherwise just do a test just disabling HDMI CEC ...
              any other app installed from market or alternative market?
                you got an error in Velocity plugin, cause probably it's not been updated by the plugin mantainer for the new kodi 17. Just contact him or check if someone is working on it on kodi forum.
                  No app installed after flash and HDMI CEC is disabled. I hope its not a faulty RAM .
                  I know that your rom is for 2gb but it is so nice, clean and fast that is very difficult to go back to original or to the bloated of A95X .
                  If the problem is the interface a change of skin to confluence i think will help .
                    "Minor problems : needs the original remote.conf, reversed led colors (red=on , blue=standby) , cannot wake up with power button
                    (but wakes when i switch on the tv, so not really a problem)"
                    If your device wakes when you switch on the tv HDMI CEC is enabled...
                      Update:
                      in my mind comes an idea to fix the devices that cannot wake up from remote... "but it's just a test"
                      Could you kindly list me wich device cannot be woken by remote?
                      Probably i have a solution, or maybe not.
                      Just for share also for other roms developers i think the differences is in dtb.img
                      I will do a test and i will report here.
                      but i need a list of the devices...
                        Update:
                        Just for share also for other roms developer i think the differences is in dtb.img
                        Hi
                        nexbox a95x 1G/8G ,have remote onlly power off. ...Your firmware are still the best, i have testet a lot. Thanks
                          Well, i thought that HDMI CEC was enabled . But it wasn't !
                          I did some tests and found something interesting .
                          My tv is an lg (LN5400) . The input list is : Aerial, HDMI1 (the android box) , HDMI2 (a satellite receiver, always on).
                          The box is on , the tv is on , the input is HDMI1.
                          I shutdown the box and turn the TV off.
                          Then i turn the TV on . Nothing happens. Change input to Aerial nothing again.
                          But if i change the input from Aerial to HDMI1 or to HDMI2 then the box boots up .
                          The most interesting is that it doesn't matter if the HDMI CEC is enabled or not and also it doesn't matter if Simplink (HDMI CEC for LG) is enabled or disabled !
                          Then i noticed something more strange. If i turn again the TV off before the end of the boot then the TV turns on as soon as the boot ends .
                            that's really strange but... just try to switch HDMI CEC on and the off and do the test again, or really don't know what is happening
                              so... i will take a little vacation during christmas holiday, so Merry Xmas to all!
                              Xanny
                                Hi Xanny,
                                First of all thank you for the work and Merry Xmas!
                                I have a problem with the brightness fix (service.bootvideo=1). If this property is set to 1 Netflix crashes every time I want to play anything. It crashes with the error 00013. If I change the property to 0 it works fine.
                                Please help, once you are back from vacation.
                                Thank you!
