Originally posted by Xannytech View Post
thanks for the report seppdog
About games accepting just wifi i think is unavoidable, many app are developed for mobile.
About ARR, dunno why happens a log could be useful, but... how? i will try to reproduce myself... from my experience, SPMC is really unstable.
the important part of the board can could cause issue are wifi chip but if is a p212 the wifi should be the same, if you want to flash twrp there is a version 3.0.2 working perfectly : https://mega.nz/#F!ZsxV0CrB!vsR6rdmZkpI9HShdPxybog just be aware that you'll need a wired mouse to use TWRP.
My Rom should work on your device, but just copy your remote config file before just in case of it's in /system/etc/ the name of the file is remote.conf .
then if you device has a reset button try the zip file i provided.
let us now
The good news: System boot up, running good. Nice!
The bad new: bluetooth not working.
But, before flash, on the stock rom, bluetooth wasn't work. Every time i click on on/off toggle nothing happens. After flash the rom, the first time i click on/off toggle nothing happens too, so i try to restart and now bluetooth is missing in quick settings and system configuration.
Wifi is working fine.
Edit: I do remote.conf backup and put back in the right directory, but remote control don`t work now.Last edited by jefferzombie; 23 December 2016, 03:23.
Originally posted by jefferzombie View Post
So, i flashed your rom direct, no backup (yes, i know, i know!). The reason is, every time i try to flash any of both recovery images suggest for me in this thread on burning tool i got "parse burning image fail", first i think both files was corrupted, but i try to download on Vivaldi, Opera and Firefox, but every time a got this message once i try to load the image file, but, if i try to load full rom image everything goes right, so i click flash and cross my fingers.
remote.conf give permissions 644 reboot must work
About bluetooth dunno, could be defective, could be a driver missing...
Thanks Xannytech. Your new ROM installed on my Mini M8S II. Played around with it last night and it is great.
A couple of challenges still to overcome for me:
- a couple of the popular Kodi addons that I use i cant get to run yet. I've got logging on and need time to go through it in detail. Tried the 17 beta and the official 16.x build from Google Play
- I have not been able to format an SD card yet. Gets to 60% and sticks there.
More playing around tonight
Originally posted by reverendo View PostThanks Xannytech. Your new ROM installed on my Mini M8S II. Played around with it last night and it is great.
More playing around tonightso it's not a rom problem dunno.
About Kodi addons, could be that some will not work on kodi 17 if they are old and not updated by the mantainer or probably you're using a repository for a wrong version of kodi, i don't know there are many reasons and again it's not rom related, the setup i did on kodi, does nothing related to addons and i konow how kodi works pretty well
But then you used kodi 16.x from Google Play, so it's odd, there are logs in kodi directory if could you post them to me i can try to help you, but i'm pretty sure, it's not rom related. But i'm curious
I got no problem to format my sd card and due testing roms you'd do it many many timesso it's not a rom problem dunno.
Tosu i'm very sorry but i don't understand you, and more i don't understand what device you own... i will ask for the second time... what device are you talking about?
I suspect you own a MINI M8 SII? If is like this the latest official is V109 released on 07/11/2017. No problem on on wifi or whatsoever...
About Youtube i'm actually playing a vodeo in full screen without any topbar, but i did nothing probably you're using a different youtube app.
I have 2 tv box. First, Mini M8s II 2gb/8gb (AP6212 wifi chip) rev.106. Good wifi
The second, mini M8s II 2gb/16gb (AP6212A wifi chip) rev.106. Bad wifi
I have not received OTA since rev106. This is my last ota.
I see that you have posted an official rev.109.
Or that there are people who have received rev.107 but I have not.
There is another user who asks about the wifi chip. http://freaktab.com/forum/tv-player-...143#post618143
Where did you get the official rev.109?
Your mod is based on it (official rev109). Does the official rev109 have drivers for the new AP6121A?
As I commented the wifi is bad with this new chip. (I checked antenna, hadware and everything is fine)
I'm sorry for my English again
Originally posted by tosu View Post
Sorry for my English.
http://freaktab.com/forum/tv-player-...845#post617845
Then he passed it to me.
i don't know if V109 contains new drivers, probably yes, the fastest way is to do a test yourself, 3 minutes of flashing 15 minutes to put all the setting back
About antenna hardware i don't think a tape with a very thin copper cable is a good antenna hardware (you wrote everything is fine) so:
I simply removed the old antenna and soldered the new one on the motherboard, it's a micro antenna cable so two point of soldering.
I buyed this antenna with cable then i created hole in the chassis, and installed the external antenna. the gain is incredible from 1mbs to 15mbs, so actually you're working without an antenna...Last edited by Xannytech; 23 December 2016, 14:43.
Obviously you cannot burn a recovery with usb burning tool, you should put recovery.img in a sd card and reboot pushing with a toothpick the reset button, then follow one of the guides on freaktaboor everywhere on web ...
About bluetooth dunno, could be defective, could be a driver missing.... But strange, first i try to put the img file on the sd card an restart and nothing happens, the device boot in stock recovery every time. i will try the remote soon.
Thank you so much!
It's a vicious came from flashing roms in smartphones. But strange, first i try to put the img file on the sd card an restart and nothing happens, the device boot in stock recovery every time. i will try the remote soon.
Thank you so much!Last edited by Xannytech; 23 December 2016, 14:54.
no, bajann he simply downloaded kodi 16.1 from playstore...
i will post some log excerpts later.
thanks all
There are currently 2329 users online. 0 members and 2329 guests.
