Originally posted by rajawaqas View Post
I searched that and found's user data folder where I saw the file name guisettings.xml instead of advance settings.xml?....you searched in a wrong place mate. there are two directory in system named org.xmbc.kodi. But if you are using a sdcard as memory and gave authorization to move files, they are in sdcard/android/data/
if not search with totalcommander for advancedsettings.xml .
Originally posted by flomuson View PostHi, Very good job, thanks !
is it possible to add "Touchscreen" compatibility ?
thanksbut maybe there is an xposed module for that... dunno.
Originally posted by flomuson View PostOK.. thanks.. i will see for xposed module...
other question : is it possible to set "mouse sensibility"... because with my 55" TV... its very slow....
But i did nothing it's an android settings built in.
I would just suggest you to buy an Mx3 airmouse 13$
Originally posted by prahjister View PostC120 airmouse is good as well
yes is very nice but i found very useful to have 4 programmable ir remote keys (1 tv on/off (beside off key works by default), 1 tvbox on/off, 1 to change between av sources and 1 free for now) and a pretty good mic. i was very near to buy a C120 then i discovered mx3, was love at first sightLast edited by Xannytech; 29 December 2016, 02:18.
There are currently 1644 users online. 1 members and 1643 guests.
