If the Rom/Mod after your testing has interest and it's ok, i would like to concentrate myself in a Android TV Rom.
If you're scared to lose updates, don't worry, if a update will come out i'll upload a new upgraded mod.
WARNING:
I'm not responsible and nor the forum that hosts my ROM is, of any damage or malfunction caused on your device, during the flash or the use of my ROM.
You'll take the responsibility of what you do.
To burn my Rom you need Amlogic_USB_burning_tool_2.0.8 and a male to male USB cable, 1 male to your pc, the other on the usb port near the HDMI.
you can follow this guide: http://androidpcreview.com/how-to-use-the-amlogic-usb-burning-tool-to-manually-update-firmware/3749/
DOWNLOAD LINK:
MINIM8SII_XTMOD_P .IMG file
MINIM8SII XTMOD P +TWRP RECOVERY .IMG file
ZIP Version (unzip the content in a empty sd card insert and reboot in recovery with toothpick metod to install)
MINIM8SII XTMOD P+TWRP UPDATE ZIP
Enjoy!
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by totor54 View PostI apologize for the answer but vldim can help you for the version
I everyone. So today I try to plug my Gamepad controller via the usb dongle as bluetooth doesn't work with my Nexbox A5.
But by doing that the keyboard of my MX3 air-mouse doesn't work anymore, even after unplug-in the gamepad dongle.
I try a bunch of different settings to try to make it work. Best I could come with is by pressing "alt" I get letter in minuscule and by pressing "CAPS" each key give me a number... but no Caps or specials characters.
I don't konw if any of you know why it's doing that and how to fix it? Or if someone could give me the default settings with MX3 remote.
ON THE NEXBOX A95X im having problems when i switch the tv to a different input.. and switch it back to the a95x i get a blank screen .. and it wont wake up.. any suggestions? i replaced the remoteconfig file with the original .. everything works while the box is on .. but it wont power the box on or wake it up.. but it will turn it offLast edited by DONDIDIT; 20 December 2016, 04:24.
Originally posted by DONDIDITON THE NEXBOX A95X im having problems when i switch the tv to a different input.. and switch it back to the a95x i get a blank screen .. and it wont wake up.. any suggestions? i replaced the remoteconfig file with the original .. everything works while the box is on .. but it wont power the box on or wake it up.. but it will turn it off
Originally posted by Idnom View Post
Mine is TX 5 Pro, what is the right file for this..Sorry I'm just new in here. Thank you.
Originally posted by Xannytech View Post
it depends if you want to flash with usb male to male or with sdcard it's your choice, but if you cannot chose from a method or another i advice you to not do anything until you understand better about these procedures
yes I understand the procedures, but it has an error on my unit so I can't continue the procedures. I'm tired of my stock rom and would like to try yours, because it always lags even the new official firmware version for my TX5 Pro.
use Amlogic_USB_burning_tool_2.0.8
There are currently 2355 users online. 0 members and 2355 guests.
