What about adding a close all apps option to recent apps? It is annoying to drag each app.
Originally posted by wolfynwo View PostOk. Russians... Anyway regarding our toy, rv107 is on the latest boxes (libreelec forum confirmation) but i can't find it.
Actually i'm working to add a reboot option... if i got freetime... actually you can do that with xposed too.
If you or someone else could find V107 post it here.
Originally posted by Cosmo20Beast View PostHonestly, I'm not sure. Here's the most in-depth specs on it. Do I need to physically open the box to know? This has a dual band wifi adapter.
https://www.amazon.com/Leelbox-Andro.../dp/B01MXL1XBY
Hello.
Tryed on x96 and working amazing. Much thanks.
The only thing is that my remote controll is not working and im using a mouse. Tryed all the remote.conf you left on the media but none of them works.
I was searching and cant find anything about it.
The remote is same as that in the pic.
Just this missing to be perfect.
Congratz Xannytech
Congratz Xannytech
Ok, thank you.
I will try it tonight after work.
that on pic is exactly what i bought on ****...
I already tryed the google but didnt saw anything about that remote. Or i am not searching well.
anyway if that doesnt work, i think i will try to find the original fw and try to get the file.
I will leave news later
Thank you.
METHOD 1 : Amlogic burning tool and use this file :MINIM8SII XTMOD P +TWRP RECOVERY .IMG file
METHOD 2 : ZIP Version (unzip the content in a empty sd card insert and reboot in recovery with toothpick metod to install) MINIM8SII XTMOD P+TWRP UPDATE ZIP
There are currently 6970 users online. 2 members and 6968 guests.
