Originally posted by Xannytech View Post
Hmm i did a test myself probably does not work... i found i way but it's too near to piracy and i won't , so i'm thinking to realease an updated rom without two things that are giving me problems, Google cast service and reboot option (causes some crashes occasionally)
Originally posted by mallox View Post
Will try to have the Wifi working and update
and that reboot the devide
Bot when I try to turn on the Wifi everything froze for 5 min and come back with "Wi-fi device : Off" again
Is there something I didn't do right do add my device drivers?
I copy the AP6330 folder from my stock folder to \system\etc\wifi
Do please this simple test for me, simply edit /Sytem/build.prop line: service.bootvideo=1 then reboot i left in my Rom a modded bootvideo should have the same effect.
Just to be sure Thanks
Xanny
But if there is something esle to test I be happy
Because as I told you before you ROM is the most workable and stable so far on my box (Nexbox A5)
Thanks for your good work
@xanny the app gives 666 to display file.
So now i am using spmc latest with 666 permission and i have no issues. Only playing videos with amcodec i get fluent playing. The others 2 codecs are not playing videos fluent.
The main issue is that kodi 17 doesn't want to work with this fix, so it is better to leave it like this, anyone who wants arr should make a script into ini.d and use spmc. End of story.
What i'm trying to do now is to resolve Reboot option and chromecast service, but givves me problem of various type.
Originally posted by seppdog View PostChrome cast app do nothing...
ARR App doesnt work on SPMC or kodi 17.
Maybe I can help with a log file?
About ARR apk , i think could be useful to write in the developer thread.
Chromecast app, has to be heavily modded to work properly, and some mods has to be done in system settings and so on, was an experiment.
Wolfynwo.......is auto frame fix works on kodi17 nightly version?when i watchin movie in kodi 17 movie runs flawless...I have issue to play movie in spmc...when I watch movie through spmc, movie's characters faces become blurr in moving scene or dark scene(i describe an example "like if u turn on high digital noise filter on led display menu when digital noise filter option works and movie becomes blurry in movin scenes that type of picture problem I m facing in spmc") kindly help ?
There are currently 2844 users online. 1 members and 2843 guests.
