From your report seems to me that you tried just with .zip method with yur original fw, I think you must flash your original fw back with Amlogic_USB_burning_tool_2.0.8: If you do not have a male to male usb cable do it by yourself, cutting two old usb cable and solder the wire color matching. Or try to put your original zip upgrade file in a sd formatted in fat32, then use toothpick metod. should work. If you cannot solve, write me PM, before it's too late
