Originally posted by blyx21 View PostQuestions: how to enable navigation bar on android box. My s912 box stock firmware has no navigation bar and status bar. I figured out status bar but not the navigation bar. Tythis is not a tvbox help center ...in other words PM me for this kind of question or you're off-topic, but first check if are simply hidden clicking and moving up the mouse or air mouse from the lower bottom of the screen then, if not... there are various way to do that.
Originally posted by Xannytech View Post
i never had problem and it' safer and faster, but i understand you... ah wolfynwo probably i need you to test the zip file of the new version based on official V1.09
If yes I can test if the .zip installs ok and the casual use of them both.
Also If you want something specific to be tested please specify.
I also prefer the .zip mode installation (easier imho).
Not to forget my respect for your mod which made my tvbox work like never before.
Regards.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
have you checked if windows recognnize properly the device?
OR try to load firmware and press start, then attach the device pushing reset button with a toothpick
have you checked if windows recognnize properhing reset button with a toothpick
So a little update, testing was going pretty well, so maybe tomorrow i will post the new version link in .img and zip format.
RELEASE NOTE/MODIFICATION FROM PREVIOUS VERSION:
- Based on new Mini M8S II v109 dated 7th November 2016;
- New Bootlogo + new BootVideo;
- Init.d Support Built in (without any external program);
- Removed Init.d Zipalign script pratically unuseful on 6.01;
- Added Sd speed optimization tweak;
- Fixed a unharmful and almost invisible linking bug caused by Amlogic Customization Tool that i used for fast customization process.
- Added in Kernel AutoRefresh Chmod Permissions;
- New Darkscreen fix, thanks for the idea goes to crazzian;
- System Memory optimizations;
- Removed some unuseful APK;
- Updated some APK
- added a Reboot APK ( my framework.res Mod is too instable and it's partially working);
- More refined tweaking and aestetical corrections;
- for sure many things i forgot to write.
Xanny
P.S. a particular thanks to all my testers
There are currently 5404 users online. 4 members and 5400 guests.
