Originally posted by njhulei77 View PostI love this firmware. It works fine on my mini m8sII, and solve the wife unsteady issue! Great job. Thanks!Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by jefferzombie View PostHi there! Today I get my first android box, but it has a obscure brand (like most Chinese products). Printed on the case is 'Exbom OTT-A10' and in Android system 'MediaBox p212'. Trying to find exact 'model' don't return anything, so it's hard to find where to start, I try to identify some other device that shares the same board, the most near I can get was 'Tanix TX5' the 'non-pro' version (s905x, 2gb ram, 8gb nand).
So, my questions: can I flash this Rom on this device, since 'almost every p212 boards should work'?
Can I flash custom recovery to make a stock Rom backup, right? But I don't know what recovery build I use for this.
Any help will be appreciated! Thanks!
My Rom should work on your device, but just copy your remote config file before just in case of it's in /system/etc/ the name of the file is remote.conf .
then if you device has a reset button try the zip file i provided.
let us now
So....
Tested the ROM last night.
Flashed, adjust all things, installed SPMC,....
ARR is working!
ROM is fast and stable so far!
Very good job!
2 things I have found:
1. some games accept only internet connection via WIFI and not via ethernet port. (You have to unplug the ethernet cable and connect via WIFI. Parallel is not working because you get no IP)
2. On the first startup ARR is working. When you switch after a movie to another app (chrome, youtube,...) and then back to SPMC ARR is not working anymore.
Than you must restart the box. All other attempts (restart SPMC,...) are not working.
Overall: The ROM is the best I have seen so far!
Some sake is on the way!
thx Xanny!
ARR is working!
Very good job!
thx Xanny!
About games accepting just wifi i think is unavoidable, many app are developed for mobile.
About ARR, dunno why happens a log could be useful, but... how? i will try to reproduce myself... from my experience, SPMC is really unstable.
Originally posted by Xannytech
the important part of the board can could cause issue are wifi chip but if is a p212 the wifi should be the same, if you want to flash twrp there is a version 3.0.2 working perfectly : https://mega.nz/#F!ZsxV0CrB!vsR6rdmZkpI9HShdPxybog just be aware that you'll need a wired mouse to use TWRP.
let us now
Originally posted by Xannytech View Post
Hi Tosu, just please specify your device i wrote before to another user i cannot guessthis Rom is based on V109 Official (kernel compiled 7/11/2016) Fw for Mini M8S II, has autoframerate enabled in kernel by me, but you've to use SPMC, i prefer Kodi 17b6 for many reasons, but if you're interested in autorefresh you'd use SPMC.
About ethernet i did some net optimizations, but i never used ethernet it so maybe some other user could give you a correct reply to you.
AP6212 wifi chip and new AP6212A is less download and coverage. It may need to modify the driver to give the same performance.
Thanks.
By the way, I do not know if this rom fixes it but can you remove the top bar of the time in the youtube application ?. It is very uncomfortable not to be able to see full screen.
Originally posted by tosu View Post
I use the latest firmware 13.10.2016 for OTA ¿rev.106?. I have never received any more from the OTA manufacturer. Can I receive OTA from another manufacturer or compatible model?
Thanks.
I suspect you own a MINI M8 SII? If is like this the latest official is V109 released on 07/11/2017. No problem on on wifi or whatsoever...
About Youtube i'm actually playing a vodeo in full screen without any topbar, but i did nothing probably you're using a different youtube app.
Thanks.
There are currently 3545 users online. 0 members and 3545 guests.
