Originally posted by Xannytech View Post
Your reset switch is working, but your original FW has a non standard way to flash, probably is the uboot, i don't know.
the only way i know actually, but i'm happy that you're curious and would like to help, is at this time to flash back TWRP (because you gone back to original recovery), and then use the file i provided to the other nexbox users, the script will flash back uboot, recovery etc, so the device will accept back the odd methos they choose to flash, and with toothpick method you can flash back your original 2/16 fw.
No software can block a reset switch, because the reset is done simply shorcircuiting two wire, no chip, no software.
Thanks a lot Xanny
Xannytech,
Just to let you know that the cast to youtube is not working on my Nexbox A5.
I did a fast read of the last couple page on the forum and saw that you were looking to have people run test for you on AP6330 device. I be happy to do so. I will go back read more closely and should have time to test by tomorrow.
Originally posted by jmgandia View Post
I was trying to link the reset switch with the remote on button. Maybe what disable the reset switch also is preventing the remote on button to work. I flashed the zip file, but without the firmware files, only the *.img files, and the reset switch was working again, but the system is gone, I don't know if it was erased or was inaccesible, so I reflashed the original firmware. Is ti possible that the boot.img or bootloader.img are responsible for the switch and the on/off button? Can I flash only those files without losing the system?
Thanks a lot Xanny
Boot.img contains... ok is too long to explain and will become a developer lesson... anyway...
Just to be sure, what exactly did to my zip and which file you removed...?
Not so easy to understand for normal users what is firmware, to me seem that you just removed system partition
Is dangerous for your device do such experimentations without knowledge... be careful!Last edited by Xannytech; 05 January 2017, 02:04.
But for now:
https://mega.nz/#!plVhCD7S!FNOupsbsP...DWMc3JJ5mvQ_YI
copy AP6330 folder in /system/etc/wifi . Obviously give to it the right permissions AP6330 folder permissions 755 and give 644 to all the file inside the folder. Reboot and let me know.Last edited by Xannytech; 05 January 2017, 02:15.
Originally posted by Xannytech View PostJust to be sure, what exactly did to my zip and which file you removed...?
I only flashed the boot.img, bootloader.img, dtb.img, logo.img and recovery.img, removing the system files. I supposed that this would leave the system untouched, but after reboot the system didn't start.
I am having headaches with stuttering in my nexbox a95x 2gb/16gb. With original firmware kodi and spmc usually are smooth, but sometimes stutter arises unexplained. Other apps stutter no matter what I do, or the display hz. Ted talk stutters but Ted TV is working fine. Amazon Prime Video sometimes seems to work fine, other times not. More than simple stuttering it seems like faulty screen redrawing. With Xanny's firmware the video playback has improved a lot, but those apps keep not showing smooth playback, except kodi and spmc. I don't know if it's system's fault or device's or app's. Is there some config file I can modify to try to lessen the stuttering?
I've realized that kodi doesn't notice change in display hz. If I start kodi at 60hz, play some video, then change settings to 24hz, then return to kodi and play again, then kodi will not notice the 24p and keeps playing with 3:2 pulldown, causing judder. That was a headache until I realized that. Am I missing some config option?
Originally posted by jmgandia View PostI am having headaches with stuttering in my nexbox a95x 2gb/16gb. With original firmware kodi and spmc usually are smooth, but sometimes stutter arises unexplained. Other apps stutter no matter what I do, or the display hz. Ted talk stutters but Ted TV is working fine. Amazon Prime Video sometimes seems to work fine, other times not. More than simple stuttering it seems like faulty screen redrawing. With Xanny's firmware the video playback has improved a lot, but those apps keep not showing smooth playback, except kodi and spmc. I don't know if it's system's fault or device's or app's. Is there some config file I can modify to try to lessen the stuttering?
About the settings... there are so many things to change and many are not accessible for you.
Flash it through TWRP and let me know... it's important for you and other nexbox users
NEXBOX BOOTLOADERLast edited by Xannytech; 05 January 2017, 13:15.
There are currently 3476 users online. 1 members and 3475 guests.
