Originally posted by Xannytech View Post
Anyway test again insmod /system/lib/compat.ko
i'm quite sure you're giving command not from a root shell (or not as superuser)
to avoid any problem it's better to use adb shell, but i do not remeber if you have a connection of any type with your device, and from what i understand you obviously (without any offence) you're not so skilled
Originally posted by hjpca View PostI typed is su then enter..then I typed in insmod /system/lib/compat.ko it didn't do anything..just shows root@p212:/#the command has been accepted
Now please :
insmod /system/lib/cfg80211.ko
then check if wifi chip gives signs of life
Originally posted by prahjister View Posttry to mount system rw....i think below is correct
mount -o remount,rw /system, i do everything through adb shell, but maybe using terminal he does not get to type su at the beginning, isn't needed to mount /system rw just to insmod a module, i asked that chmod test just to be sure he copied the .ko files in the right dir. :P
Now the next thing to test to try to add that fu*ing driver is to check wpa_supplicant service, but as you know doing tests just giving command to a user through a forum it's a mess and it's really slow
what i learned now is that the problem does not sit in kernel modules.
What's your opinion?
Originally posted by hjpca View Postno it wasn't me doing anything wrong..its just not working that way..i am working on a file now..if I get it working I will send it to you
Code:getprop | grep wlan
yes wifi and remote working..just waiting for mega to finish uploading then you can take a lookyes hjpca
Could just tell me what you did, so i can eventually find solution for other drivers?
Edit:
So long time to upload... means a big file!Last edited by Xannytech; 10 January 2017, 22:50.
There are currently 2170 users online. 2 members and 2168 guests.
