But anyway before flashing can you copy and send me a link of your /system/etc/wifi folder, cold be very useful to check (for all) and in case of emergency.
Originally posted by Lordgoku View Post
But anyway before flashing can you copy and send me a link of your /system/etc/wifi folder, cold be very useful to check (for all) and in case of emergency.Last edited by Xannytech; 13 January 2017, 19:21.
Originally posted by Xannytech View Post
My rom has Ap212A fw inside, but i dunno if someone has done a test.
Ok thanks. Should I use .IMG or Zip file?it's a really important thing to backup some files, i need tem to compare
, the original .img or sd file of your Mini M8SII isn't anywhere.
So what i can suggest you before flashing is to do a nandroid backup before.
Simply download TWRP then put it in a empty sd card switch off your device and with a toothpick click the reset button at the bottom of it, plugging power and keeping the reset clicked.
After a while you'll boot into TWRP recovery then through menus you'll find backup. save it in a safe place...
Then you can use any flashing method you like zip or .img.
Gimme your folder then i will replyit's a really important thing to backup some files, i need tem to compare
but the problem is I'm not sure that my box have AP6212A,
I supposed it because I bought it a short time ago and I can´t open it because warranty
I upload my folder: https://mega.nz/#!E9YS0LgR!yBUqRNRIC...eXVlrIgQmfHjeE
warranty for a chinese box? Amazon i hope
Anyway you can safely flash my rom, i checked the folder and are identical byte to byte the v109.
You can choose yourself which method would like to use for flashing the result is identical.
Your rom works very well. I suggest an app called "Root Booster" , increases speed significantly on this rom and stock romLast edited by Lordgoku; 13 January 2017, 23:03.
I just got home and turned on the Beelink I have a s912 device on the way (wanting gigabit ethernet and the better gpu) so probably won't keep this one around too long But I wanted to at least report on WIFI hardware as well as the remote.conf i promised.
The remote.conf is in the zip file attached on this post, and the wifi chip used is the standard amlogic one that most other boxes share, so, nothing your fw does not support, (Did not test wifi performance, i ethernet connect it) Beelink Mini MX3 II
XTMOD EX 2.3 open test beta version I WILL NOT POST THIS LINK IN FIRST PAGE
Test version should solve some issues like device that cannot be wake up with remote (nexbox), and many others, some wifi chips like AP6377 that comes with some Tanix tx5 pro are not supported, they need a whole new rom as manufaturer does, i will do it but in future.
I will be very busy from now, so left your impressions on forum and try to help each otherSometimes i will come to read.
Thanks to all for reading.
RELEASE NOTE/MODIFICATION FROM PREVIOUS VERSION:
- Based as the one before on Mini M8S II v109 firmware dated 7th November 2016;
- TWRP recovery totally reassembled by me for 6.01 devices;
- Updated Google services from 9.2.5.6 to 10.0.84;
- Fixed (probably) a bug some user reported with Netflix;
- Added SPMC optimizations;
- Update sqlite3 binary;
- Fixed some init.d scripts and added some for tweaking a bit;
- Added Ap6330 wifi chip support*;
- Added some more Bt chip support;
- Added few tweaks in init.d;
- Trimmed and optimized many ROM parameters for a little bit more speed (Antutu around 34100 stable);
- Fixed some invisible to the user, but ugly bug left by the manufacturer;
- Updated most of the APKS
- Removed VLC, Added Google Search (i use voice command a lot), SPMC instead of Kodi (cause many uses it and not Kodi 17)
- for sure many things i forgot to write.
Enjoy
Xanny
XTMOD v2.3 BETA4 .IMG (to be flashed with Amlogic burning tool and a male to male usb cable)
XTMOD v2.3 BETA4 ZIP (to be flashed with twrp or zip method with toothpick)
Please report device type and working not working issues, personal preferences, or request are not acceptedLast edited by Xannytech; 21 January 2017, 23:49.
Hi Xannytech, I installed your new version (just tested connection speed, great !). I have noticed that I cannot connect to my Google account. Thanx for your help!
My device is the mini m8s II.
Edit: I made a clean reinstall, problem solved!Last edited by mu1111; 15 January 2017, 14:21.
Originally posted by mu1111 View PostHi Xannytech, I installed your new version (just tested connection speed, great !). I have noticed that I cannot connect to my Google account. Thanx for your help!
Edit: I made a clean reinstall, problem solved!was odd that you cannot connect i use the same rom, just some different apk
There are currently 2061 users online. 2 members and 2059 guests.
