Originally posted by Xannytech View Post
Originally posted by jmgandia View Post
I prefer to have the statusbar accesible, but sometimes it does not hide, so I will need to look for an app that easily hide the bar in the meantime. Also I usually hide the navbar permanently in the build.prop, because I don't use it so much and some apps save the area of the navbar when in fullscreen (so actually no fullscreen). I think is an app issue, but if I want to have the navbar when I use only a mouse I need to change the build.prop and reboot. Don't know if it can be done without rebooting.
Originally posted by rajawaqas View PostPlz hide the status bar because I am using app (hide system bar (full Screen) ) for the hide status bar.
I would like to finish thise mods until tomorrow cause i got a big project in my "real" life... for about 6 week i will be very very busy.
Originally posted by Xannytech View Postgood cause many write MX3 but "original" mx3 was a s905 device ;=)
yes please send me a link so i can add it to the remotes folder
Ah very important before flashing which wifi chip has your device?
also i will check wifi chip to be sure before reflashing! no need to worry, i'll come back and post info on the box
ehm where is the remote.conf?
Originally posted by permabanned_pete View Post
https://www.amazon.com/Beelink-Mini-...t_top?ie=UTF8;
Wont be here until tomorrow anyway. i will back it up regardless soon as i get it. My older S905x box purchased in November which i had been using upside down to make the wifi not as bad, the heatsink was held on only be thermal paste, a few days fell off. Awful design
If you want me to share the remote conf let me know and i will upload it for you.
Originally posted by mallox View Post
That will be great
With Kodi 17RC I get DD but no DTS at all
Whit SPMC (frequent crash) :
using "IEC passthough" --> I get DD and DTS when (but I often ear craking sound)
using "RAW passthough" --> I get DD but no DTS
Plex: with ROM v2 I don't get DD or DTS
with ROM v1 DD was woking but no DTS
But' what is weird is that the passthoughfix don't seem to change anything on my box. other than screwing the sound sometime (all audio sound like robot sound).
Originally posted by ssarava9 View Post
Do we have a fix for this issue, i was told in other forum there is a firware update yesterday that fixed the DTS issue, if anyone come across this please post the url
http://forum.kodi.tv/showthread.php?...812#pid2499812
But from my understanding it's not all box that have the problem. For some the passthoughfix.apk is working but fo other like the Nexbox it's not.
I just try Kodi RC3 and it's the same thing. No DTS.
Many thanks
i would like to try the passthroughfix.apk, can someone please share the latest file url to download ?
Many thanksPlease consider making a Donation to freakTab
There are currently 3030 users online. 0 members and 3030 guests.
