Originally posted by Xannytech View Post
why don't simply use reboot to twrp? I left a useful app for reboot. About remote it's odd someone on xda told me that goes well ... have you tried just to use any other key to wakeup? sorry but i have no free time to investigate... maybe later...
Google play app, never had that issue...
Originally posted by jmgandia View Post
I tried twrp with the dummy update.zip but it didn't work. I will try another twrp options. From twrp I can't see the usb drives. Is this normal or it's an issue with my nexbox. Regarding the remote I've tried each button and it does not start the box, I think the xda user doesn't have a nexbox. I have changed the remote.conf for the nexbox a95x so the remote home button works. Before I was using the Multilanguage Keymap Redefiner app to do this. Changing the line ' 0x42 172' to ' 0x42 102' the home button works and I don't need the app. Maybe you can include the modifyed remote.conf in the final rom.
Originally posted by dkholm56 View Post
I'm sure you're right....once I load your rom and click Uboot/kernel, how do I replace it with same from my stock rom? sorry for so many questions.
But just t be sure, are you trolling me?anyway.. i'm working i'm not on forum 24H i came here just to relax a bit
Originally posted by jmgandia View PostI have an issue with the chrome browser. I can't download anything 'because there is no sdcard'. I googled this but I couldn't find the solution.
I just uninstalled it and reinstalled from the Play Store and the problem went away.
Originally posted by rajawaqas View Postafter restore logo command execute but startup logo still distorted and wake up device still not working after proper shutdown?
Try to do it manually and post if there are errors:
Code:su dd if=/system/media/logo.img of=/dev/block/logo
About wake up after shutdown probably just nexbox uses a very particular bootloader, i really can't imagine what they did.
Updated beta file with framework fixed so no more errors of any kind, just bootlogo, but will be fixed in final; was a experiment for some kind of devices.
Zipfile for sdcard method flashing posted.
Everything is (and will be for beta) in my #611 POST
Enjoy.Last edited by Xannytech; 16 January 2017, 14:17.
There are currently 2355 users online. 0 members and 2355 guests.
