Originally posted by jmgandia View Post
Originally posted by Xannytech View Post
i replied on this particular topic many times, just nexbox (i think) uses a non standard bootloader, so usign my standard bootloader loose some abilities, it's not a matter of remote codes, or config, it's a sligthly different way to access on some part of the basic I/O system, totally harmful, but you'll lose some functionality.
download THIS_FILE with totalcommander go to /system/priv-app/ open PrebuiltGmsCore folder delete the .apk and copy the one you just downloaded give 644 permissions reboot
no never had blank screen, and i think just one time i used lan as source video, but i see lot iptv... do a test disabling amcodec just because normally is the main culpritlt me know.
How many of you use spmc through wifi / ethernet?
I've done some testing. Installed spmc 16.5.2, several hours of playing videos and no issues. Then installed 16.5.3, a few minutes and it stoped playing and returned to list. Then I remembered that al first the box was connected through ethernet and I didn't have any issues with spmc. So I tested with ethernet 16.5.3 and 16.5.5 and several hours without issues. So, maybe it's related to wifi, but this is a random issue. I'll keep testing.
Originally posted by bajann View PostLook post 757 ,don't use spmc 14.2 and kodi 16.1
Edit: Ok. I know you've seen the post. Some people in spmc forum at github are experiencing similar issues, so I am trying to figure out why. Now I've played several hours through ethernet and no issues and wanted to know if someone else is having issues only through wifi
Originally posted by masterpirlo View PostIs it possible to you could make a img where the standard config file is for A95X so I can use remote right after burning the img? Btw thanks for your great work!
Anyway as i wrote many time, WHEN i will post or decide to upload a FINAL stable version, and when i will have more freetime i will work and then post rom done specifically for NExbox and devices using 9377 wifi chips.
Actually free time permitting i want to add more functionalities than base original fw, also doing experimentations that could work or not, i hope to solve and add more things beta to beta until i found nothing more to experiment
Originally posted by Dru79 View PostI don't have this box. I want to buy it but I'm afraid that it will have unsupported WiFi chip.until now i found 0 (zero) users with a MINI M8S II and AP6212A wifi chip, when i ask to post that directory the result is... directory identical or "i don't know what wifi chip i own but i asked because i read..." or i do not have this box.
In my rom there are configs and fw for Ap6212A chip but none tested because none knows or none has that chip, no trace elsewhere or anywhere of a firmware with wifi AP6212A chip.
So what i can reply it should work and if anyone got one please post system/etc/wifi folder.
There are currently 2642 users online. 1 members and 2641 guests.
