The problem of Kodi 16 is that amlcodec give problem... so you need to disable it, in SPMC you can add any addon working on kodi 16 is a fork of te original kodi 16 android developer that left kodi team.
I found no differences in "the way to install addons", simply you nedd to change skin to confluence?
ABOUT Autorefresh who is interested do a test for me:
In settings activate hdmi self adaptation, is in playersettings .open terminal app or through adb (if you don't know what is no problem use teminal)
Code:su echo "2" > /sys/class/tv/policy_fr_auto cat /sys/class/tv/policy_fr_auto
If it's ok will be included by default in XTRom Stable Version.
Xanny
N.B.
If works and you're happy give thanks to fandm on 4pda forum and bajann who reported that thing to me.Last edited by Xannytech; 17 January 2017, 20:44.
Originally posted by Xannytech View PostABOUT Autorefresh who is interested do a test for me:
In settings activate hdmi self adaptation, is in playeropen terminal app or through adb (if you don't know what is no problem use teminal)
Xanny
N.B.
Originally posted by FaTa1-Err0r View PostYour ROM is amazing, I love how fast it is and the customization on my x96.
But for a local Belgian IPTV app I need the ROM to be completely root-less.
(Is there anyone that has a completely root-less ROM) or
Could you make a root-less version of your ROM @Xannytech?
Or simply open SuperSu and click system unroot (maybe it's written in a different way), it's too tiresome to use apps?
Xanny
Use a Xposed module to block root control, i think there is something for it.
Xanny
I've only got it to work on stock samsung tablet. All my other devices are rooted.
I'm a regular freaktab and XDA follower and tester, software developer in real life, but haven't found the time to learn ROM development, sorry.
Xanny
N.B.
Originally posted by Rccm1112 View PostI installed beta 3 from post 611 on my 1g+8g a95x 6.0. This is the fastest my a95x has ever moved. It moves as fast if not faster than my 2gb boxes.
I have noticed one one issue that I haven't had on other roms. When I run Kodi 16.1 I get a black no input screen. I can fix it by unplugging the hdmi cable and plugging it in. I've tried enabling cec, self adaptation, and pass through fix but nothing seems to help. Any advice?
I've tried both, it's a really sucky app that somehow checks things and there are no ways around it using xposed and using the supersu app to unroot, I've tried, not working :-( I don't know why, it keeps saying it's rooted :-(
I'm a regular freaktab and XDA follower and tester, software developer in real life, but haven't found the time to learn ROM development, sorry.i was joking i added the smiles, i never tested the unrooting done through SuperSu app.
CHeck with receiverstop, or can you give me a link to your app, probably is simpler to remove root check?
I can do a unrooted rom, but what i need i this particular period is time, t do that on my pc half an hour (just to check everything), but then i need time to upload, and write to all that is a special version or they will whine that is unrooted and many messages to explain.
I hope you understand it's not that i wouldn't like to help you.
There are currently 1410 users online. 1 members and 1409 guests.
