Originally posted by luke_70it View PostI have a mini M8S II device with AP6212A and i can confirm Wi-Fi is working with Xannytech rom (i tested only beta3).
Inviato dal mio P027 utilizzando Tapatalk
I expect my mini M8S II in a few days, and it will most probably have the AP6212A chip. So, I can't wait to flash it with XannyTech's rom.
p.s. May I ask, how did you know you have the AP 6212A wi-fi chip? Did you open the box, or is there any "hardware info" app you used to get the information?
I just realized that I don't need to press the reset switch to connect to burn tool, with xanytech rom. When I said that burn tool didn't recognize my x96 with the original rom, it was because I connected the cable to the wrong usb port (port 2). I didn't know it has to be connected to usb port 1, because that port was used for wireless keyboard dongle at that time. So, x96 doesn't lose that functionality after flashing xannytech's rom, nor with the original rom. Sorry if I gave misleading information.
Beta 4 in uploading
- AutoFramerate (system patch) works on mxplayer and i hope in some other apps (does not depend on rom but on app developer) active by default; to activate/deactivate go to settings deactivate/activate hdmi self adaptation, is in playersettings.;
- updated some apps;
- readded Backup/update app.
- some litte experimentation around.
BETA4 .IMG online
BETA4 .ZIP online
updated post #611Last edited by Xannytech; 21 January 2017, 23:50.
Originally posted by Xannytech View Post
oh didn't know that
Originally posted by tosu View Post
It will work, the original firmware works and this ROM is based on it. But the problem is that the box with chip ap6212a is very unstable the wifi signal and very weak. With the ap6212 chip does not pass is high and good, even with the internal antenna. Maybe it's fixed with an external antenna but I doubt it. Maybe it's a drivers problem? Maybe they are not well driver prepared and lack development? Or is the ap6212A chip very bad?
If someone can give me files from a system born with Ap6212A chip that i can compare or add, it's good, but magically none has different files from mine and none can provide me a simple files, they mostly just read what someone wrote, without any evidence.
Anything different from this are just words, impressions, or "someone told me", not fact.
Fact are firmwares files: nvram_ap6212a.txt that is yet inside /system/etc/wifi/6212 directory
So tosu , i need files to compare or are just words, i never found a fw with AP6212A files different from mine, and i know what i mean.
Should I just connect the box to the PC via a male to male usb cable, find all the files within /system/etc/wifi/6212 directory and send them to you ?
Originally posted by LostEchoes
This is really great news !
I asked to s905x libreelec developer and he told me my wifi chip was ap6212a. I send him my android wifi drivers folder and he added support for it in libreelec...
I know it because i tried libreelec on my m8sii and wifi didn't work.
Originally posted by ddogishere View PostHi does nyone know how to reinstall Google play store after i deleted it using root explorer as i was trying to manually update it. Thank you for your help
There are currently 3081 users online. 0 members and 3081 guests.
