Thanks for all your help
4.5 Fixed Link
https://mega.nz/#!20ZhySAD!UGl85KSsk...-U4L57tFECdYeo
Really Fast, amazing work
Couldn´t make recovery work
My children´s favorite game Lego Star Wars Complete Saga Force closes
Is there anyway I can apply this update as an upgrade to my existing ROM , please help.
Originally posted by steocullen91I'll try it tomorrow on the x96 and see it it works and report back. If not I'll go back to 4.
Originally posted by ssarava9 View Post
Will you flash as new rom or upgrade to an existing rom so that you can keep all apps and data ? If later can you please tell me how to upgrade
"HANDS ARE NATURES FORKS" -Rigby
I'll try it tomorrow and see if I can manage to keep my data. If not I'll try backup everything with titanium and see if it restores properly.
Originally posted by Xannytech View Post
i can add vorking recovery but tell me what you did different from me
Then in the tool itself i´ve changed only the uboot file. First option only in level 1 select.
In 8 hours i will be at home and ost Screenshot
It take me 2 or 3 trys to make it work. I know that you don´t have this devuce but i can test 4 u.
It probally works cause the app itself repacks and recalculate all sizes. I don´t know how to calculate the partition size options by myself.
Do you have any clue why my games are force closing ?
Using the Amlogic customization tool i´ve extracted the whole rom except for the last option.
Anway it's useless to unpack the whole rom just to change uboot.
Use just the first four option and probably also recovery will work.
Do not play with partitions size, too many other things has to be checked and changed.
There are currently 1934 users online. 1 members and 1933 guests.
