Originally posted by Jraf View Post
No problem ! i'am a rookie and confess i don't really understand what is done here. rom ? read only memory... certainly another use here ! i used to be a chemist...
did not try to config smpc, because kodi17 works without configuring anything apart language et local settings.and it's enough for my use.
i tried to solve the problem with the home page configuring squarehome but did not succed. but again, it does not bother me. i thought it was a bug, so i reported it. not a bug, i'll give a try to config again, much harder this time.
my real goal is to view easily my movies. much easier than my (lot of ) bluerays, with all those manipulations and unskipable advertisings.
it was effortless with wd tv live, but this box is unable to read H/265. so i bought the tanix, and problems with sound, problems with video, problems...
but with your rom it becomes to be effortless again, thank you.Anyway if you succeded log in to a forum and use a computer, i think you'll figure out how to set a simple launcher like SquareHome, if you're not interested in Android, i suggest to try Libreelec.
Originally posted by fluoir View Post
Thank you steocullen91 for an idea. However I tried to boot with sd card with xannytech's rom which has recovery.img and it didn't boot. Or how do you mean "put twrp on sd" ? ...to download twrp from somewhere else?
Does anybody has another idea how can I access twrp please?
I'm wondering now what would cause the ping issue on SPMC and FTMC lol."HANDS ARE NATURES FORKS" -Rigby
Hi steocullen91 Please tell me if I understand you right. I create bootable sd card with amlogic bootcard maker and copy inside only recovery.img from xannytech's flasshable zip. rom? What should I rename to recovery.img. Xannytech's rom already has file named recovery.img....I think you mean something else...
Originally posted by fluoir View PostHi steocullen91 Please tell me if I understand you right. I create bootable sd card with amlogic bootcard maker and copy inside only recovery.img from xannytech's flasshable zip. rom? What should I rename to recovery.img. Xannytech's rom already has file named recovery.img....I think you mean something else..."HANDS ARE NATURES FORKS" -Rigby
Originally posted by steocullen91 View Post
If's it's already called recovery.img then just leave it. As far as I know you just have to have recovery.img on the root of the SD card for it to work.
Sorry you actually need aml_autoscript on the root of the card too. Just take it from an SD firmware.
So your sd card should have
aml_autoscript
recovery.img
Then you need to hold the recovery button (toothpick method)
I tried that with mine and it booted into twrp.
Try this and rename it to recovery.img https://www.androidfilehost.com/?fid=24686679545611078"HANDS ARE NATURES FORKS" -Rigby
Originally posted by steocullen91 View PostSorry you actually need aml_autoscript and factory_update_param.aml on the root of the card too. Just take them 2 files from an sd firmware
aml_autoscript
recovery.img
It contains these 4 files:
recovery.img
Update.zip
Update.zip.md5
I don't see aml_autoscript ...you are mentioning...where could I get that?
...Ok going to try by your link now...
I tried to unzip to my sd card the whole xannytech's latest rom (Unzip_to_sd_XTMOD_EXTB4)
recovery.img
Update.zip
Update.zip.md5
http://freaktab.com/filedata/fetch?i...1&d=1446951071
Unzip that and put it on the root of the SD card.
That recovery actually isn't working try this one https://mega.nz/#F!ZsxV0CrB!vsR6rdmZkpI9HShdPxybog
The one in this link definitely works just get the 2 files in this post unzip them both and put them on the SD card and rename twrp to recovery.img.
Sorry for all the hoops I should've tested it first on my own box before posting.Last edited by steocullen91; 12 February 2017, 19:03."HANDS ARE NATURES FORKS" -Rigby
Originally posted by fluoir View PostIt doesn't work I am still stuck at broken yellow screen with lines .... it doesn't go to twrp ...any idea why? Did exactly what you said.
....maybe there is a problem with aml_autoscript ?
The autoscript linked just above your last post is the one I used."HANDS ARE NATURES FORKS" -Rigby
Which firmware are you currently running and which box is it? That works for me on my x96 on a stock rom.
Thank you for helping me with this....I have nexbox a95x 1g/8g and xannytech's rom (BETA4 .ZIP) ...Last edited by fluoir; 12 February 2017, 20:09.
Then download reboot recovery and while the system is on run reboot recovery it's also on the play store.
Links to apk files in case:
If that still doesn't work try this recovery image instead http://konstakang.com/devices/nexbox_a95x/TWRP/"HANDS ARE NATURES FORKS" -Rigby
There are currently 1611 users online. 0 members and 1611 guests.
