Originally posted by digitalriver View Post
Can you tell me, where is this magic power off option? I use this variant(little video):
_https://youtu.be/uUf_hqisRAA
I will repeat, in previous rom was all fine(for me)
And yes your device simply are in suspend not in power off.
2nd from the video i saw that you are using spmc in touch mode... why do not use simply confluence mode? It's in MAGIC SPMC settings
about bootlogo it's odd because i got no problem but tomorrow i will check, anyway if you want to fix open terminal and type :
su
sh system/bin/restorelogo.sh
Anyway thanks a lot for the report i will check and fix tomorrow everything.
Originally posted by bajann View Post
I just test some videos in spmc -kodi 16.1 (auto refresh rate switching didn't work on lvl 1) on lvl 2 only works with MX player no way with spmc-kodi 16.1.Maybe (jar).files???i'm really surprised about that.
My personal variant (same rom with different apks) works well.
Originally posted by bajann View PostSettings (or hold long power off/on but on on remote)
3. Next problem: After shut downing of box integrated SPMC always preparing for first start.its a little strange.
4. ES Explorer change his resolution after some operayions.
All these four problems can be seen in this little video:
_https://www.youtube.com/watch?v=lbRo1KXQI4Y
Thank you, but in those settings all good.
about ES explorer really don't know what to think.
Abour smpc first run it's normal there is a script that at every reboot clear cache and unuseful files, so spmc think it's first start.
Anyway your video are very useful
Originally posted by Xannytech View PostIt's not MAGIC or HIDDEN are just settings in settings app
2nd from the video i saw that you are using spmc in touch mode... why do not use simply confluence mode? It's in MAGIC SPMC settingsI did not set up SPMC, all settings - from firmware.
su
Originally posted by digitalriver View PostMight be hw little differences with your and my boxes. On my box usb ports shutting downs only if I use "suspend and resume". But when I use "shutdown" in magic menu - usb ports not shuttdowns.
Its not me, its youI did not set up SPMC, all settings - from firmware.
Restoring corrupted bootlogo!
No problem
About SPMC, ok i will setting up the app for the user sorry, thats the app as the programmer gave to us, i thought anyone has a personal settings to put, different languages and so on, do you prefer i set the app for you?
About restoring bootlogo... fixed the bootlogo corrupted?Last edited by Xannytech; 19 March 2017, 00:16.
Originally posted by Rasto4nik View PostBluetooth don't work on a95x(905x) 2/8. Plz fix it.
Xanny I currently do not have my Yundoo, but when I get it back I will test it out and see if everything works. I also have a few Beelink Mini M8s II's coming in on the boat, so I will be able to test with those as well and see if there are any issues. If I find anything quirky I will let you know. I even have a 4k tv so I can test out those functions too for you.
Once again thank you for your hard work. It is greatly appreicated.
Originally posted by Kuno View PostXanny I currently do not have my Yundoo, but when I get it back I will test it out and see if everything works. I also have a few Beelink Mini M8s II's coming in on the boat, so I will be able to test with those as well and see if there are any issues. If I find anything quirky I will let you know. I even have a 4k tv so I can test out those functions too for you.
That's really odd i did nothing in framework is the same of beta 4. tomorrow i will boot the rom i posted on my system and do a accurate checki'm really surprised about that.
yes it can help...
Im using your beta 4 and refresh rate not switching automatically, i use SPMC and the video plays in a small tiny box when the content has different refresh rate than UI, i tried the frameswitcher also but no use.
Any help really appreciated.
There are currently 2210 users online. 1 members and 2209 guests.
