Please advise.
Originally posted by steocullen91 View Post
Please advise.
Originally posted by ssarava9 View Post
Perfect, i will try this evening, one question though, after creating the new ROM with uboot can i upgrade on top of my other Xanny Rom using Toothpick option or using Terminal emulator with Reboot update option ? so that i can keep my apps and data, mainly Kodi data as it takes solid 30-45 mins even with restore option, the new Kodi 17 needs you to manually enable the Addons and Repository one by one and thats a pain.
Please advise."HANDS ARE NATURES FORKS" -Rigby
I actually havent used kodi 17 yet I could never get my addons to work for me. You can't install it over it you'll have to use usb burning tool unfortunately but I did see another user on here a couple of weeks back saying to use titanium backup from the play store so you can restore your data if that helps.
Originally posted by ssarava9 View PostI believe the latest Xanny build still have the Power on issue, anyone successful getting power on from remote for Nexbox A95x ?to be more precise, it's not an issue. Simply my custom is not built for nexbox, but for Mini M8S II , it's a plus that works on different systems.
Originally posted by Kuno View Post
Why does everyone want to turn their boxes off? These things only use 5 watts of power at most. Leaving them on uses less power than your microwave's clock. And besides, the mod is made for Mini M8s II :P I have it on my Yundoo and I can't even get the remote to work even with the proper remote.conf haha. Honestly I'm just happy that my box worked with this rom!
I will look for other suggestion where you can extract uboot and customize this ROM
I will wait for your next release by end of March
You can do little tweaks here and there to make it work properly on your box. I do agree it's the fastest i've seen on these boxes
The uboot change will fix the remote power on if you do it. It's actually easy enough.
Originally posted by steocullen91 View PostYou can do little tweaks here and there to make it work properly on your box. I do agree it's the fastest i've seen on these boxes
Xannytech if you don't mind me asking does that high ping happen to you in SPMC on a speed test on your Mini M8S II also? Either way would it actually effect streaming quality like have to keep stopping to buffer etc?
When i see post like above i have to say Kodi/spmc/Ftmc NOT YOUR ISSUE. Switching to kodi17 from spmc will do NOTHING for your wifi connections what ever is happening is not program related. I have spmc installed on 20 devices Ftmc on everyone of them too. Telling someone that switching to beta 17 kodi build helped your wifi buffering is like stating you put a new heated car seat in your car and you get better mileage now. Nothing related to wifi. Settings and use maybeMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 2509 users online. 2 members and 2507 guests.
