Thanks again for the work. I have the latest version on my x96. Definitely the fastest most stable rom of them all. Most others even have a problem where they're too dark (like Full RGB instead of Limited RGB but you can't change it). This one seems like it's on Limited RGB like it should be"HANDS ARE NATURES FORKS" -Rigby
Now I can only hope the real final version will not have any changes so that I won't have to go through the same flashing procedure all over again :-)
Thanks for the great work, once again.
P.s. Any possibility that your final version will be built upon the latest 112 version of the stock rom?
Originally posted by LostEchoes View Post
Just to inform you, I've moved from your beta4 rom to this Test before final version, and so far everything seems to be running smoothly.
EDIT: i found them... i think is just a custom MEGABOX version, but tomorrow i will check bit by bitLast edited by Xannytech; 28 March 2017, 00:29.
Magendanz had a look at it here: http://freaktab.com/forum/tv-player-...roid-tv/page14
I flashed it on my Mini M8S II 2/8 box. There's a lot more bloat and they added a splash screen to 'fix' the brightness.
Originally posted by rahzel View PostMagendanz had a look at it here: http://freaktab.com/forum/tv-player-...roid-tv/page14
Camera app
SystemUI
TvSettings
Services.jar
Some kernel modules regarding: wifi, mali and prealloc.
And what is funny but not tested a new remote.conf
I don't think to use it as a base rom, but i can use some part of it if worth the work.
Originally posted by MasterBoy71 View Post
Stolen from Xannytech.......LOL ;-)
The work mostly come from the user that help us experimenting.
Some things are stolen directly from me in other roms, but we are here for share, so really it's not a problem, and i "stoled" myself some nice things from others, it's normal.
But in 15 years of "career" my roms are always the fastest and the most stableThe secret... i use them personally.
Originally posted by Xannytech View Post
The diffs are (not considering the Megabox customizations):
Camera app
SystemUI
TvSettings
Services.jar
I guess I will have to upgrade once again when you release the real Final version :-)
I'm sure it will be worth it.
Ok, thank you for looking into it.
So if you're happy you can stay with it, it's pratically very close to final.
I will upload before just a very experimental version because i would like to test some stuff, then the final will be the final of this kind for a long time.
Next project Android TV Rom.
Originally posted by steocullen91Thanks again for the work. I have the latest version on my x96. Definitely the fastest most stable rom of them all. Most others even have a problem where they're too dark (like Full RGB instead of Limited RGB but you can't change it). This one seems like it's on Limited RGB like it should be
For sure i'm one of the early adopter of the trick, but i'm not the father.
There are currently 2601 users online. 0 members and 2601 guests.
